  #1
Old August 30th, 2009, 10:46 PM
cams0820 cams0820 is offline
Default Yamaha 90: Hard to start
I have a 2003 Yamaha 90 hp 3 cylinder. In order to get the engine to start I have to take the engine cover off and move the emergency start switch from the normal position to the emergency position. Once the engine is warm I can move it back to the normal position and the engine runs fine and starts fine from the normal position for the rest of the day, just not on the initial start. I removed the carbs and gas filter and and cleaned them, I replaced the spark plugs and also the fuel/water separator but still the same problem, any ideas what to try next?
  #2
Old August 31st, 2009, 08:16 AM
Cobra Pilot Cobra Pilot is offline
Default Re: Yamaha 90: Hard to start
This engine should be started with the throttle in idle postion. Do not advance the throttle until after it starts. Everything is automatic.
  #3
Old August 31st, 2009, 09:20 AM
robert graham robert graham is offline
Smile Re: Yamaha 90: Hard to start
same motor as mine. pump primer bulb until hard, neutral throttle in closed position, press key in while turning to activate the prime start enrichening device on front of center carb. if prime start is working correctly it should feel warm/hot to the touch on top when activated. I usually crank on motor for a second or two, stop and wait a moment, then crank and she fires right up. you can experiment with slightly different combinations on your starting proceedure. the red switch should be in the "normal' position if everything else is right. My motor always seems to start better when there's a good fresh charge on the battery-guess it just spins the motor over faster. Hope this helps and good luck!
  #4
Old August 31st, 2009, 04:45 PM
99yam40 99yam40 is offline
It does not require the key to be pushed in , just turn the key to start.
  #5
Old August 31st, 2009, 04:56 PM
pushing the key in on cold start actuates the prime start enrichening device on the middle carb, allowing for much easier starts when motor is cold. after motor is warmed up no need to push key in to start. prime start is just similar to the choke on many other motors. try that and hopefully she'll crank up good for you. Good Luck!
  #6
Old September 1st, 2009, 09:37 AM
The Yamaha prime start enrichment System does not require you to do anything to make it work.
The system works by itself and is always active unless you turn it off manually by the red lever.
The two wires are Black to ground and the blue connects to the wire coming off of the regulator which feeds voltage to the unit while the motor is running, heating it up ,expanding the wax pellet and extending the needle closing off the passage stopping the extra fuel from flowing. as long as it is warmed up there is no fuel flow through it.
Pushing the key in does not have anything to do with this system from what I have read in the manuals, that (Pushing the key) was the way the old electric chokes worked in the past to close the butterflies and it was the way my old 35 HP Johnson worked by squirting fuel into the carb, with a electric solenoid but it is not needed for the Yamaha system.
If you know how pushing in on the key helps please enlighten us with that information
  #7
Old September 1st, 2009, 10:14 AM
my impression is that pushing the key in activates the prime start feature. if it doesn't then what does pushing the key in do? All these years and my motor starts right up cold and i've never moved that red emergency switch. Hope we can get some clarification on this because one of us has to be wrong. maybe Rodbolt or one of the other guru's could offer their take on this subject. this is how we learn. Good Luck!
  #8
Old September 1st, 2009, 06:35 PM
http://forums.iboats.com/showthread....ht=prime+start
Look at this thread, it explains the system well.
I believe the problem is in the prime start enrichment system if the motor starts and runs fine except for cold starting and he is not pulling up on the idle lever while trying to start.
One thing I do not know is if the pump diaphragm is bad on the prime start system will the emergency position still work, or will the emergency position only work if the thermovalve is plugged and will not let any fuel through its passage way. Maybe this is something others can answer.
  #9
Old September 2nd, 2009, 11:44 AM
so the prime start is always ready to enrichen the mixture if it senses that the engine is cold, but if the engine is warm then prime start will detect that and not enrichen the mixture? so the magic in the system is that wax pellet, it's totally automatic and pressing in on the starter switch really does nothing? I have a Yamaha manual and an operators handbook and I really want to understand this.
  #10
Old September 2nd, 2009, 04:19 PM
My operators manual says to turn the key to start for no more than 5 seconds and then let sit for 10 sec if it did not start, and then repeat. It says nothing about pushing on the key.
  #11
Old September 2nd, 2009, 04:45 PM
I guess that push-in ignition switch on my motor is just something left over from another model with a key-activated choke. and all these years I've been pushing on that switch and may as well have been peeing off the dock! well it's never too late to learn something. someday when I've got some spare time I may just disassemble that prime start just to see how it works on the inside, because it's still a mystery to me. Good Luck!
  #12
Old September 8th, 2009, 10:15 PM
malardman malardman is offline
Had the same problem w/ my 1999 90hp tlrx, the hole time it was water in the carbs and plugged jets, and yes I have a water fuel seperator, now it runs great, even though I tore them down three times, and pushing the key in does nothing, the prime start enrichment is all electronic. mine starts in -10,20deg just fine, cranking the key.
  #13
Old September 9th, 2009, 10:09 AM
Glad you got it running and in the process learned a lot more about your motor. I know that I continue to learn from these forums. Beats the heck out of going to the boat dealer$$ with every little problem. Good Luck!
  #14
Old October 6th, 2009, 08:33 PM
wellsc1 wellsc1 is offline
I have a 2003 90TLRB. It too doesn't not require the ignition to be pushed in. It'a all automatic. I have to keep that in mind not to confuse it with my 40 hp Force that needs the switch pushed to choke the engine (or squirt a bit of gas into the carb).
__________________
Carl
Carolina Skiff 175 Sea Chaser, 90hp Yamaha 2-stroke
River City Marine 14' AL flat-bottom, 40hp Force 2-stroke
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
50 hp Yamaha 2-stroke hard to start stormiespop Yamaha & Suzuki Outboards 5 November 16th, 2009 02:36 PM
Hard to start yamaha 115 4InAROWE Yamaha & Suzuki Outboards 3 June 1st, 2008 09:59 AM
yamaha 200 ox66 hard start rjh1974 Yamaha & Suzuki Outboards 3 August 7th, 2005 11:21 PM
Yamaha 115 hard start elpaso Yamaha & Suzuki Outboards 3 April 10th, 2004 06:45 AM
Yamaha 130 Hard to Start deedledog Yamaha & Suzuki Outboards 11 March 13th, 2004 03:45 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
