  #1
Old August 30th, 2009, 10:59 AM
raymeek raymeek is offline
Default damaged prop
I'm looking at a 1990 Sea Ray 17 with a Merc 3.0. While being loaded on the trailer last year they forgot to put up the outdrive. The outdrive hit hard enough to break off the lower 4 inches of the outdrive and then destroy the prop. I plan on putting water to it, start the motor, put it in gear and see if it shakes or wobbles or grinds. Any thoughts on the likely damage? How tough are these outdrives?
  #2
Old August 31st, 2009, 08:19 AM
nlain nlain is offline
Master Chief Petty Officer
Default Re: damaged prop
They are pretty tough. I broke the skeg of my Alpha drive while on plane, about 20 mph, did not realize my depth finder transducer was kicked up and reading behind the boat instead of under the stern, made a sharp turn, hit hard sand bottom, snap, skeg hit prop and put a nick in it near the hub, still runs great, I did pull the lower unit and have the skeg replaced, you can pull both the prop and lower unit and have them repaired, if prop is not damaged too bad.
__________________
http://myboat.wikispaces.com/
2004 Sea Ray 185 Sport, 4.3L,190, Alpha
1994 GMC 4X4 1500, 5.7L
  #3
Old August 31st, 2009, 09:01 AM
Just to give you and idea of before and after. I had already ordered another prop so I did change props, I will have the original repaired and have a spare.
Broken skeg
Repaired skeg
__________________
  #4
Old August 31st, 2009, 10:05 AM
nlain
Thanks for the reply and pictures. Your damage was probably covered by insurance but any idea what the repair cost was. I'll have to repair this myself since I'm buying the boat this way. It looks like I can purchases a remanufactured lower unit for about $800 and I'll probably install it myself unless it's really tough and then I'll have the local SeaRay dealer do it.
Any thoughts about this?
Ray
  #5
Old August 31st, 2009, 10:31 AM
If the only damage is the skeg broken off, you can pull the lower unit and take it to a prop shop and they can weld either a new skeg or just a piece to what is left, they can also repair the prop if damage is not too bad. Somewhere around $200 to $250 should cover the cost of the repairs to both. Your outdrive case is not broken is it, if not and the prop shaft is not bent there should be no problem, usually the aluminum props will give before gear or shaft damaged occurs. One other thing, get yourself a manual, it will guide you in the repairs you are talking about whether it is just R&R or replacement of the lower unit, you might as well replace the water pump impeller while the lower unit is off.
__________________
  #6
Old August 31st, 2009, 11:49 PM
nlain
Thanks again for the information. I don't believe the lower unit case is cracked I'll inspect it very carefully. Hopefully it's not. Then I'll take your advise, get a manual, remove the lower unit, have it repaired and install a new water pump. What's the best manual in your opinion?
Ray
  #7
Old September 1st, 2009, 09:46 AM
The best manual is the factory Mercruiser manuals, they are pricey, but you can go to the iboats store and get a Seloc manual which should have everything you will need. I believe the 1964 to 1991 manual would be the one for you. Link below
http://www.iboats.com/Boat_Parts_Acc...0--submit.y.10
__________________
  #8
Old September 1st, 2009, 11:39 AM
boat1010's Avatar
boat1010 boat1010 is online now
If it is just the skeg that was damaged you can just buy a new skeg replacement that just screws onto what is left on the lower unit. They have them in overtons.
__________________
"Spend a little money, save a lot of time"
  #9
Old September 2nd, 2009, 01:30 AM
WOW, thanks for the information, I could have spent months trying to find this information and you guys provided it in a day.
Thanks
Ray
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Damaged prop, no #'s ?? help please cthamil Prop Questions and Topics 1 August 23rd, 2007 03:56 AM
Damaged Prop - Now What? boatgrunt Prop Questions and Topics 1 July 16th, 2006 02:24 AM
Damaged Prop? shanklejo Johnson & Evinrude Outboards 9 July 11th, 2006 08:16 PM
Damaged Prop? shanklejo Prop Questions and Topics 2 July 10th, 2006 06:28 PM
Prop damaged. michaelsen Boat Topics and Questions (not engine topics) 4 December 23rd, 2002 03:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
