Does anyone have a good way (or know how!) to replace the toilet lines going to the holding tank and then also the vent lines and such that go to the out left and right under the floor to the outside in the side of boat?
I've looked and have no idea on how this is done post manufacture. I have a new holding tank that needs to go in because the other was original and was holding a stink that I couldn't get out. Now I've been told that the old lines have been saturated and should be replaced also.
The lines go under the electrical panel on the port side and into the shower and on the starboard side they go under the couch and sink. I can't see any way of doing this without ripping up the floor or cutting a large hole so I can get my body in so I can connect the new hose to the fitting going through the hull.
