  #1
Old August 30th, 2009, 08:22 AM
Tim/Rinker192 Tim/Rinker192 is offline
Default Smart Tabs?
I have an '07 Rinker 192 with 5.0MPI and Alpha 1 drive and extended swim deck. Am trying to correct the issue with time to get on plane with a load (skiing, tubing and/or carrying heavy load).
I/ve tried 14.5X19" 3-blade; 14X18" 4-blade and a 15X17" 3-blade. All work well for a set spectrum of use. I understand that the Smart Tabs can be installed on the 192, but where? (Pix if you have 'em please). I'd like to not have to change props all the time and to get better handling.
Any advice is appreciated.
  #2
Old August 31st, 2009, 12:16 PM
JBeach327 JBeach327 is offline
Default Re: Smart Tabs?
read post on list to the left. Do not carry more then 600 lbs passenger and gear. That will help.
  #3
Old September 1st, 2009, 09:10 AM
mvn's Avatar
mvn mvn is offline
Tim,
Right here.....
__________________
2005 Rinker 192, 4.3L Volvo SX, SX Smart Tabs, Precision Props 4-blade SS prop
2007 GMC 2500HD Duramax/Allison @450 hp haulin' it all
  #4
Old September 2nd, 2009, 12:55 AM
Thanks for the pictures. Gives me the courage to take a drill to my boat. I'll put them on this week.
  #5
Old September 2nd, 2009, 09:17 AM
mvn's Avatar
mvn mvn is offline
Which model of tabs did you get, the stainless ones or the plastic ones? I've got a few tips for you once I know which ones.
Mark
__________________
  #6
Old September 3rd, 2009, 08:59 PM
I got the 80lb. plastic tabs. Looks like a straight forward install. Measure twice drill once.
  #7
Old September 4th, 2009, 10:40 AM
mvn's Avatar
mvn mvn is offline
Tim,
I'm thinking the 80 lb. units will give you too much tab pressure. I found the 60's were perfect.
There's a lot of talk in the installation manual about the angle of the tabs in the down position relative to the bottom of the hull. I believe it's somewhere around 25 degrees. If you install the tab plate onto the lower mounting bracket without the actuator and let it free hang, you will see that the tab will be at the perfect angle when placed on the transom (assuming your transom is at 90 degress to the hull bottom). I slid the mounting bracket up about 1/4 of an inch to clear the radius at the hull/transom corner.
Use masking tape over the places you want to drill. Only drill as deep as you need to go with the proper drill size. Use 3M 4000 (not 5000) marine sealant in the holes and under the screw head for a perfect seal.
Mark
__________________
  #8
Old September 4th, 2009, 08:08 PM
Mark,
Thanks for the info. I did see from several forum posts that Rinker 192 owners found the #60 tabs to work best. I called Nauticus and spoke w rep who said I should go w the #80. I have a heavy 5.0MPI weighing me down in back. It is probably what causes me the planing and porpoising issues I've had since new. Easy enough to change out the actuator if I need to go down to #60.
I have to modify my trailer before I can get the tabs on. I realized today that the runners extend out past the transom area where I need to put the tabs.
Thanks again. Great to be able to pick the brains of others who have been there.
Tim.
  #9
Old September 8th, 2009, 12:56 PM
mvn's Avatar
mvn mvn is offline
Tim,
Oops! I forgot you had the 5.0. Let us know how the 80's work for you.
Mark
PS Planing and porpoising issues seem to be hull related (I had them too with the 4.3L).
__________________
  #10
Old September 11th, 2009, 02:25 PM
samtoby samtoby is offline
I posted this under the Rinker owners topic, but this topic probably more suitable... sorry for the duplicates
I have a 2009 Rinker 192 BR that I recently installed the smart tabs on as well. When i talked to the reseller, they suggested i go with the ST1290-80 model. I have teh 4.3L Mercruiser which i believe they rate at 220HP. I also have a SS 19pitch high five prop installed as well i ordered the boat with the Extended swim platform. I also have a samson tower installed (which is rather heavy) Last year i was having trouble with getting the boat to plane, this year, no problem with that, but the trim tabs will almost toss the boat from port to starboard and vice versa depending upon load etc. I originally installed them at the 25 degrees as per the manual, but have since moved them way back, to close to 10 -12 degrees. I can still feel them push the boat but not the way they did before. My question is, are these too much tab for this boat? Should i replace them with the SX model? I have attached a couple photos.
Thanks
  #11
Old September 12th, 2009, 08:22 AM
I installed the SX 80lb tabs on my 192 last weekend. After having it on the water 2 times I am very pleased with the improvements. Porpoising is gone on flat to moderate chop and what little there is, in rough water, is controlable with trim or throttle. Gets up on plane in seconds w/o pointing bow into the sky. Rides much flatter on the water too. GPS has me at 17MPH at slowest planning speed. That's down about 3MPH. Do not know about the top speed yet. I need to put the 19" pitch 3-blade back on. Currently have the 4 blade 18" on.
As to the question of whether to use 60 or 80 lb actuators; the 80's seem to work well on my boat. I probably will not need to use the 5th setting as it seems to behave well on setting 3 with four adults. I plan on taking the wife and kids tubing and wake boarding this weekend so I'll see how it works on that setting.
I have not noticed the tipping problem that SAMTOBY references. That could be a function of the higher center of gravity from the tower. I am not sure if changing to SX tabs would correct that. Also not sure if that happens just while towing a skier or at all times.
All in all I wish I put these tabs on last year. It is a different boat now. Wife can even drive it. Maybe I can ski now.
  #12
Old September 14th, 2009, 04:13 PM
Roadrage Roadrage is offline
Had the boat out for the last time this year. 9 people on board 1550lbs .
2 or 3 on the tube @ any given time . I was quite impressed with the lil v6 .
The SmartTabs definatly helped out . Boat blew out in very tight turns when I was tossing the monsters off the tube . But boat was very loaded with bodies & the boat was not very well balanced as everyone was a heavyweight . I was also not trimmed down all the way before the turn so I may have just been the Capt. fault .I never had such a load on board before.
Normaly I only have half that load at best .
Jim
  #13
Old September 14th, 2009, 10:30 PM
mvn's Avatar
mvn mvn is offline
Jim,
What prop are you running? You will find that it's probably not the captain's fault. After installing SX tabs, I found I could not keep the prop hooked up in tight turns when towing a tube. The answer was to go to a cupped stainless steel prop. Blowouts are a thing of the past!
Mark
__________________
  #14
Old September 14th, 2009, 10:40 PM
bifflefan's Avatar
bifflefan bifflefan is offline
That is a sharp looking boat....
Thinking of painting mine black now...
__________________
1983 22' Starcraft SC221 Bowrider 470 Mercury
1974 16' Starcraft American Bowrider 85 HP Johnson
Once you eliminate the impossible, What ever is left,
No matter how unlikely, Must be the problem.
  #15
Old September 15th, 2009, 08:47 AM
Quote:
Originally Posted by mvn View Post
Jim,
Mark
A 19p Hi5 is what I have , I never had that happen before (Blowout)so it kinda took me by suprise .But to be fair I never had that much weight in my boat before. Still want to see my prop guy about repitching it to 20p.If its crazy $$,I will just buy a 20p 4 blade something over winter.Winterized the engine already so no chance I will have to get the 383mpi replacement engine next spring.
Samtoby ,that black hull looks Sweet
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Smart tabs ST1610 or Bennett trim tabs for 28' twin engine cabin cruiser. rs2k Boat Topics and Questions (not engine topics) 2 June 3rd, 2009 09:42 PM
Trim Tabs (Smart Tabs .vs. Instatrim or Bennett) MN86_4winns Boat Topics and Questions (not engine topics) 21 May 28th, 2009 10:23 AM
Smart tabs vs Hydraulic trim tabs Brijoe00 Boat Topics and Questions (not engine topics) 13 August 14th, 2008 11:32 PM
Smart Tabs, regular Bennett-type tabs or QL interceptors? stevens Boat Topics and Questions (not engine topics) 18 May 13th, 2005 01:10 PM
Smart Tabs Vs. Conventional trim tabs? Kevin Hite Boat Topics and Questions (not engine topics) 3 July 31st, 2003 03:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
