  #1
Old August 30th, 2009, 07:24 AM
baysailerbill baysailerbill is offline
Default 1981 Carver Mariner 33' Needs Holding Tank
I just purchased a 1981 Carver Mariner 33' with no waist holding tank. The head has a Port-A-Potty with a 9 gallon holding tank built in. We are going to be living aboard the boat during the summer months and this system just won't do. I would love to install an electric head with a good sized holding tank.
Has anyone installed a holding tank in a 33' Mariner? Does anyone have a holding tank on there boat now? If so, where is it mounted and/or located on the boat? What size is it?
Any suggestions would be appreciated.
Thanks,
BILL
  #2
Old August 30th, 2009, 11:54 AM
arks's Avatar
arks arks is offline
Default Re: 1981 Carver Mariner 33' Needs Holding Tank
Bill-
First, welcome to iboats!
I don't have a 33 Mariner but my 34 Silverton had a similar problem.
Mine originally came with an oversized portapottie (6 gallon).
The previous owner opened the bilge compartments and measured the largest space. He found a similar-sized poly tank (20 gallon) and installed it below the floor. He had to cut some of the floor framing but it was all replaced and reinforced.
He installed a 3-way valve for the black water (tank-mascerator-pumpout), rigged up a new SeaEra electric head, then ran all the lines and wiring.
The end result is very nice. Pumpouts are easy and the tank has enough capacity for 4 people for a week. The electric head has been maintenance-free for the past 5 years and requires NO pumping- just push a button!
__________________
"Winter Dream"
Silverton 34C
White/Green
Lowe 1446 BigJon
w/Johnson 25HP
  #3
Old August 30th, 2009, 12:52 PM
weasel5 weasel5 is offline
Cool Re: 1981 Carver Mariner 33' Needs Holding Tank
i have a 81 carver mariner 33'. my toilet has a small waste tank built in which goes to a hand driven transfer pump located under the hatch in front of the refrigerator, which pumps into the main holding tank which is under the floor in the v-berth. you can see the end of it from that same hatch. the deck fitting is on the starboard side, midship. hope this helps.
  #4
Old August 31st, 2009, 07:20 AM
Thanks for your help everyone.
I was looking at the boat yesterday and I think putting the holding tank under the V-berth is the way to go. The pumpout nozzle is already mounted on the starboard side and running a new hose to it should not be a problem. I am going to install an electric head. This winter I will pull up the floor and measure the space so I can fit in the largest tank possible.
Thanks again,
BILL
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
holding tank Capt. Mike Boat Restoration and Building 9 January 21st, 2008 12:01 PM
pump out vs holding tank johndoe Boat Topics and Questions (not engine topics) 5 February 23rd, 2006 05:20 AM
Holding tank sporter Boat Topics and Questions (not engine topics) 0 May 9th, 2005 11:15 AM
Holding Tank sporter Boat Topics and Questions (not engine topics) 1 June 29th, 2004 04:13 PM
Holding Tank SS MAYFLOAT Boat Topics and Questions (not engine topics) 0 June 2nd, 2001 06:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
