  #1
Old August 29th, 2009, 01:53 PM
SnookHunter SnookHunter is offline
Default Yamaha 25 4stroke starts then dies.
I have a 2004 Yamaha 4stroke that won't stay running on its own.
I last used the boat about 6 weeks ago. I tried to start it and it wouldn't start at all. I figured carbs had trash in them. It did. Looked like someone threw up in there. Cleaned them up and then I soaked the carb for about 6 hours in carb cleaner. Bought a rebuild kit as well as a fuel pump just for piece of mind. I also replaced the fuel lines, gas tank, spark plugs, primer bulb,fuel filter, and anti siphon valve. Pumped the primer bulb until it was hard. Ok, try to start it for about 30 seconds and nothing. Check the container with the fuel filter and its dry. Put some gas in there and it turned over very briefly. But never fully started running. There is a black tube with a screen over it above the carb that sucks air in and when I put my hand over it, it fired up. So I quickly grabbed the throttle and reved it up and it died. Ok so I repeat the process and put my hand over the tube and it starts again this time I started pumping the primer bulb and it stayed running and reved up fine. But when you stop pumping the primer bulb it dies in about 30 seconds. It will run fine as long as you pump the bulb. But it will not start on its own unless I put my hand over that black tube.
Any ideas? I should also mention my drain screw broke off in the carb when I tried to remove because it was corroded, but I sealed it with jbweld. Could that be my problem or more trash in the carb? Also are attwood products any good? That's was the gas tank is and it seems like a cheap pos.
Thanks for any help anyone could offer.
  #2
Old August 29th, 2009, 02:39 PM
rodbolt rodbolt is offline
Default Re: Yamaha 25 4stroke starts then dies.
more trash in the carb and you possibly installed the fuel pump incorrectly or its sucking air.
by placing your hand over the air intake you force it rich bypassing all the carb running circuits.
  #3
Old August 29th, 2009, 06:33 PM
Thanks for the reply. I don't think I have the fuel pump stalled correctly. It came pre assembled from the factory and I would assume there is only one way to installed it?
Do you think letting the carb soak for 24 hours or so will help get rid of any trash that might be in the carb?
  #4
Old August 30th, 2009, 01:52 PM
eng241 eng241 is offline
Have had very little luck with carb cleaner. You need to find someone who has an utrasonic cleaner with heat. Those carbs will bee spotless after they are done and you will not have any problems with them.
  #5
Old August 30th, 2009, 11:45 PM
Soaked the carb overnight in carb cleaner. And then reinstalled everything. I primed the bulb until it was hard and it fired up on its own after 10 seconds of cranking and then died again. It idled fine for about 30 seconds and the nothing. After the intial start up the motor would not start again unless I put my hand over the intake. Wont stay running unless I prime the bulb. I noticed the container that encloses my fuel filter barely had any gas in it. That means my problem is from the carb back correct?
Also nobody answered my question about the drain screw. The drain screw broke off from corrosion when I tried to take it off. I sealed it with jbweld. Could the missing drain screw be my problem?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
OMC Starts then dies laiberg Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 June 5th, 2009 05:11 PM
Yamaha 200 HPDI starts and dies!! GW West Coast Yamaha & Suzuki Outboards 2 April 20th, 2009 08:10 PM
Starts, dies, doesn't start, then starts Big One Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 3rd, 2007 06:44 PM
2000 Yamaha 4stroke Starts then Dies ak_sowa Yamaha & Suzuki Outboards 1 June 7th, 2007 01:09 AM
Yamaha 25hp (2stroke)? Nissan 18hp(4stroke)? Honda 15hp(4stroke)? Spidybot Non-Repair Outboard Discussions 4 October 26th, 2003 06:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
