  #1
Old August 28th, 2009, 11:25 PM
BSDenning's Avatar
BSDenning BSDenning is offline
Question Pressure treated wood on an aluminum jon boat
Hello,
Last weekend I built a new front deck and subflooring in my 14 foot Lowe jon boat with pressure treated plywood, 2x2's, and 2x4's. I allowed the lumber to dry over the past week and tomorrow I am planning to glue the carpet on. I just read something on the internet that said something about the pressure treated wood may react with the aluminum in the boat. Is this true? If it is true, is there something I can do to protect my boat? I really want to use the wood that I've already got because it was really expensive and I've already got it built. Thanks in advance for your help.
-Bret
  #2
Old August 28th, 2009, 11:34 PM
Huron Angler's Avatar
Huron Angler Huron Angler is online now
Send a message via MSN to Huron Angler
Default Re: Pressure treated wood on an aluminum jon boat
From what I gather the pressure-treated lumber causes corrosion and in bad cases pitting that can be a major problem. I would think that the more water gets in the boat the bigger the problem as the chemicals leach out of the wood.
As far as your situation...maybe if you coat the wood with several layers of epoxy resin and then paint it the chemicals won't be able to get out?
I'm sure someone will come along and post that can confirm or deny my idea and maybe offer a better solution. I had a piece of treated on my rear bench seat and took it off a while ago for the same reason. Good luck.
__________________
1979 16' Starcraft SuperSport w/ '70 80hp Mercury
1960s 12' AeroCraft w/ '55 5.5hp Johnson
"The gods do not deduct from man's allotted span the hours spent in fishing"
  #3
Old August 28th, 2009, 11:41 PM
BSDenning's Avatar
ok. So maybe I can coat my treated wood with something that will keep the chemicals from reacting with my wood. Does anyone have an idea of exactly what I should use?
  #4
Old August 29th, 2009, 12:36 AM
BSDenning's Avatar
I've got some green paint. I was planning on painting my boat tomorrow or Sunday. Do you think that if I also paint the treated wood, it will help it to not corrode my boat?
  #5
Old August 29th, 2009, 07:41 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
where ever it contacts the aluminum it needs a barrier.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #6
Old August 29th, 2009, 08:26 AM
snal snal is offline
Quote:
This is correct. The newer treated wood (new within the last few years) will eat up aluminum, I've seen it happen with flashings where decks are tied to homes. Local building codes won't allow aluminum flashing near the new treated wood. You must also use the correct nails/screws made specifically for treated wood.
I used some regular screws on a deck that I built on our camper last year, had to pull some of the deck boards up to run a water line this year...the screws wouldn't back out because there was nothing left of them below the head...that's within a year!
  #7
Old August 29th, 2009, 09:45 AM
BSDenning's Avatar
I checked the screws that I used and they are the special screws meant for treated lumber. So, there's no problem there.
I guess I'm just going to try to paint the wood. Hopefully that will protect my aluminum job boat.
  #8
Old August 29th, 2009, 12:06 PM
xxlurchxx xxlurchxx is offline
You may also want to put a layer of somthing on major points of contact. As I think pressure points are where you are most likely to see reactions.
  #9
Old August 29th, 2009, 12:14 PM
109jb's Avatar
109jb 109jb is offline
The difference between the jon boats and the typical v-hull aluminum boats here on the forum is that the jon boat has paint on it both inside and out. That itself is one barrier to protect from the corrosion. The typical boat restores you read about on the forum are like my Starcraft was. Bare aluminum on the inside of the hull. Rather that trying to seal the wood to keep the chemicals in I would seal the boat to keep the chemical out. Something very durable at the contact points. Something like truck bedliner. Just my 2 cents.
  #10
Old August 29th, 2009, 04:31 PM
oops!'s Avatar
oops! oops! is offline
Quote:
all you need is a barrier.....some kind of barrier..paint it self ....may come off due to flex...this could be thin rubber...(like pool liner)....or as suggested a paint on rubberised coating....but it must be seperated....or all your work will be in vain
__________________
IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
  #11
Old August 29th, 2009, 07:54 PM
DANZIG's Avatar
DANZIG DANZIG is online now
Treated? No, No, and No. Do not do it! Not If you care about the boat anyway.
At some point your barrier is going to fail and you will not notice until it is too late. Murphy says so.
Chuck that wood after using it as a template for the non treated you are going to put in.
  #12
Old August 29th, 2009, 08:17 PM
oops!'s Avatar
this is a standard correct answer.....
pt wood is a no no on tinnys.....
but if you must.....now you know how.
__________________
  #13
Old August 30th, 2009, 12:14 AM
BSDenning's Avatar
ok. Well, I've already used pressure treated wood to build my front deck and my subflooring. I have already carpeted the wood. So throwing the wood out and starting over is not an option.
I am in the process right now of puting a lair of paint on my jon boat. I plan to put a second lair of paint on my jon boat in the morning. I also plan to paint the wood on all points of contact tomorrow. I'm considering putting a layer of carpet on points of contact so that the paint doesn't ware off.
Are there any more ideas on how I can put a barrier between the pressure treated lumber and my boat?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
aluminum vs. treated wood superflydudebike Boat Topics and Questions (not engine topics) 5 July 13th, 2009 05:46 PM
Treated wood? ccarver Boat Restoration and Building 2 October 8th, 2008 04:50 PM
Treated Wood and Fiberglass Reel Poor Boat Restoration and Building 3 July 23rd, 2007 04:10 PM
Treated wood & Corrosion... RyanB Boat Restoration and Building 10 May 19th, 2006 02:41 PM
wood transom on aluminum boat nigelbear Boat Restoration and Building 6 February 13th, 2004 08:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
