  #1
Old August 28th, 2009, 09:15 PM
gloveral gloveral is offline
Default Mariner Magnum 40--How Hot is too Hot, Fry an Ignition?
Took my mariner magnum 40 project to the lake today after successfully transplanting it onto my boat and replacing all of the electronics. It seems to be running hot.
The motor pumped water, but it took about 5-10 seconds for it to make it out of the tell tale. However, the stream was strong and heavy.
Pumped well throuh idle and still at WOT and all ranges. After about 10 mins of operation the motor started to surge. Seems like it was losing 2 cylinders. I brought it to idle and there is quite a bit of steam coming out of the upper exhaust and the water out of the tell tale was HOT.
Water did not immidately steam off of the motor (my usual back woods check) but it just seemed hot--even the flywheel was hot to touch.
I must confess I did not change the impeller and that is my next move so that could be part or all of the cause no doubt--should have done it to begin with but the stream was so strong once it started.
Here are the quetisons.
1. Does this motor have a thermostat that could be stuck
2. Should it take so long for the water to start pumping
3. Should I be seeing all of the steam after running WOT and coming to idle
4. Could it have gotten so hot it burned up my new trigger and power pack to cause it to drop cylinders
Timing is set to 3 degrees ATDC at idle and 32 degrees BTDC full advance/throttle at cranking speed with plugs out. Carbs are adusted to the rich side and I am running double oil until I can verify my oiler system is working.
Thanks for the help
  #2
Old August 28th, 2009, 09:32 PM
GDiamond GDiamond is offline
Default Re: Mariner Magnum 40--How Hot is too Hot, Fry an Ignition?
When you say upper exhaust, that is only exhaust not water too ? I'm having the same problem. I posted today with the 1995 Mercury 40hp 2 stroke (4 cylinders).
  #3
Old August 28th, 2009, 09:45 PM
I am calling the two holes in the tower just under the belly pan/power head the upper exhaust. I am getting some smoke out of there upon acceleration due to the heavy oil but just getting steam out otherwise, not seeing any water out of those holes. I get some water out of the prop when I start on muffs and also out of the tell tale, that is it. I will search for your post--as well. Mine is a 4cyl model as well (2 stroke)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mariner 40 magnum Jetblack Mercury & Mariner Outboards 1 July 24th, 2009 06:27 PM
Mariner 40 Magnum Drillers Mercury & Mariner Outboards 0 July 22nd, 2009 01:54 AM
Age of Mariner Magnum 40 Kambon Mercury & Mariner Outboards 1 May 3rd, 2009 05:54 PM
Mariner 40 Magnum old salty Mercury & Mariner Outboards 2 September 29th, 2002 08:13 PM
mariner Magnum old salty Mercury & Mariner Outboards 1 September 29th, 2002 09:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
