Keikauffer
- Aug 1, 2009
- 6
This is my first post so forgive me if I'm asking questions that have been asked many times over.
So I have already learned from this site (and the hard way) to change the impeller every 2 years to be on the safe side. I didn't do this on Wednesday
I have a Mark 25, SN: 868788, that hasn't run in about 2 years. I got it started after 4 pulls, saw water coming out of the coolant holes and thought, "I'm good to go!"
I went up the river at about half throttle and after about 1/4 mile the engine began decreasing RPMs and shut itself off. I looked at the motor and could see I could cook an egg on the side of the powerhead
I make sure the flywheel still turned, which it did and let the motor cool while I drifted back downstream. As I neared the dock, I started the motor and IDLED over to the dock. No water was coming out of the coolant holes this time.
So, here I am on your forum, humbly asking for help. I'm in the process of removing the lower unit to change the impeller but I'm wondering if there is anything else I should do while I'm working on it?
Does anyone know what the compression should be on this motor? I hope I didn't ruin the rings....
Thanks for reading my ramblings. I feel like an idiot
