timmeraw
- Jun 10, 2008
- 258
Hi,
I have begun trying to wake up a 60 Merc 300 and have worked my way thru getting the electric start working well with various issues from wiring to a starter that did not retract etc. Luckily with some great help in this forum I have avoided buying any parts(came really close to getting a $75 starter solenoid but found out it was just hot wire connection issue).
Now for the newest stumper......No Spark at all. I removed the magnito and cleaned the points, set the gap at .20 and fixed a nearly severed ground line to block etc. and crossed my fingers
and turned it over but still nothing.
One thing I noticed the second I took the cowl off is a bunch of melted brown tar running down the head and my first thought was the stator( I saw that same thing on another motor I had one time...85 Evinrude) Some knowledgeable with a barn full of old Mercs and boats told me that sometimes they overdue it on the sealant on the block or something but I am thinking it is stator or something melting. I didn't get to pull the flywheel yet as I ran out of daylight and I need to get the right sized socket(what size is it btw...1"?) and 3 bolts to fit into my puller(what size are those fine threaded ones ?).
Any hints and tips would be greatly appreciated. I was pretty excited about diagnosing and getting the electric start to begin working correctly only to be brought back
to reality when I still have no spark. As for the plugs...they are the correct Champion 6J6's(clean and not burnt or anything btw) and when I went to the local marine place today they had nothing in stock(looked up motor/yr and said they referenced B6S...and didn't have).
In any case I find it hard that all 4 would be bad and not even cough if one or two were still working.
Thanks for any thoughts on how to continue.
SIncerely,
Tim
SIncerely,
Tim
