Re: Is spark related to ignition parts temp? 15 hp evinrude 4 stroke
I have a '96 9.9 hp 4 stroke which I believe is the same engine as yours. It runs fine for a while, then quits and won't start. After sitting for a while, it runs fine again. It's getting fuel. I haven't had an opportunity to check for spark yet when it is dead. I suspect the ignition module, (power pack?), is failing at a certain temperature. I had a Dodge van with the same failure mode; it turned out to be the ignition "pickup." On the Evinrude, this is just a coil, so intermittent failure seems unlikely. The module seems more likely. Please post if you find the problem with yours and I will do the same.
I ran this thing on the dock for an hour and a half this afternoon and it didn't hickup. Out on the open water last weekend, it quit repeatedly; then it would start and run fine again after sitting for 15 or 20 minutes.
