Andy in NY
- Oct 25, 2007
- 2,109
Okay so this saturday is the splash date for my starcraft project, and hung off the back is a 74 rude 50 that i picked up almost a month ago. a little background on the motor, i traded a non running 69 johnson 55 for it. when i did the trade, it was on a boat at the time, and he took me for a ride and it performed well. it starts right up, like 1 spin and its running. after warming up it doesnt even have to be choked to start.
so yesterday i decided to do a decarb on it. things were good for the first 3 or 4 times i ran it. the last time it seemed to be a little on the hot side, i couldnt hold my finger to the powerhead for more than 2-3 seconds. when i shut it off, for about 20-30 seconds after there was this thin white smoke coming out of the exaust, didnt look like typical 2 stroke.
with no tell tale, i wasnt sure what the water pressure was like. but i do know that there was water rolling out of the exaust after i shut it off, also there was water coming out the vents on the sides of the LU and also coming out the rear of the lower unit there is a hole that had water coming out at a pretty good pressure when it was running.
i tried to test the overheat alarm, but dont know if i was doing it right. i disconnected one of the yellow wires that comes from the back of the buzzer, disconnected it from the bus bar right next to it and with the key on touched that wire to a bolt on the engine block. nothing. what else can i do to troubleshoot?
am i paranoid or is there a problem? im leaving for vacation next week and am going to replace the impellar when i get back, but i just want to get out at least once with it!!!
