disgruntled boater
- Jul 29, 2009
- 2
I recently purchased a boat with a 1992 johnson 140 that needed a lower unit. Took it to the local boat mechanic and he put a refurbished lower unit on it along with a trim motor. I put the boat in the water it started fine and idled with no problems through the no wake zone. When i went to plane out it started to climb out of the hole when the motor reved up a bit and went no where. I thought it was a spun hub on the prop, took it out put another prop on, put it back in and did the same thing. The motor sounded fine and i didnt notice any banging. took it back to the mechanic and after a month later still not fixed or out fishing.
Any help would be appreciated
