Tractor Jockey
- Jul 29, 2009
- 8
Hi, I have just purchased a 1989 bayliner 175 with a 85 hp force engine. With the engine raised, or tilted foreward oil slowly drips out of the lower unit out a very small hole. The hole is on the front side, at the bottom of the L unit. What seems odd is that it does not leak when the motor is lowered into the running position. Should I be concerned? What is it? Thank you, TJ
