oldrudedude
- Jul 3, 2008
- 480
I haven't had it in the water yet. I want to ensure the impeller is impelling before I do that. When I put the muffs on it water comes out a small hole high on the port side of the LU and a small hole low on the starboard LU. It also leaks over the top of the LU. When I run it on the muffs, water burbles out with exhaust from two 1/2" dia holes at the rear near the top of the mid section. I don't see any stream of water with enough force to indicate the impeller is working. I don't know the history of the motor. Where is the stream I should be looking for to indicate the impeller works?
