  #1
Old August 25th, 2009, 10:37 AM
DancingPaul DancingPaul is offline
Default Evinrude 120 Cooling Problem
This past weekend my engine overheated twice. The impeller and thermostats were replaced very recently. The overheating problem only occurs when running at 3,500 rpm or above. I noticed that when I get above 3,000 rpm my water pressure starts dropping. When running below 3,000 the gauge indicates about 7-8 pounds pressure. When I get above 3,000 rpm the pressure drops to 2-3 pounds pressure. The water coming out of the site check hole seems fine at low rpm but seems to drop off at higher rpm.
Questions:
1. Shouldn't the water pressure gauge show increased pressure rather than decreased pressure at higher rpm?
2. Any ideas about the cause of the problem?
Thanks
  #2
Old August 25th, 2009, 10:39 AM
ezeke ezeke is offline
Default Re: Evinrude 120 Cooling Problem
What year is your motor, the 120 cooling systems vary depending on the model?
  #3
Old August 25th, 2009, 02:41 PM
1988, 89
  #4
Old August 25th, 2009, 06:44 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Sounds like the line for the gauge is hooked into the wrong place. Most likely you have it T'd into the overboard line. It should be T'd into the line that comes from the adaptor plate and goes to the water control valve behind the throttle arm. That is, assuming you really do have a 1988 or 89 V4 looper.
  #5
Old August 25th, 2009, 06:54 PM
nymack66's Avatar
nymack66 nymack66 is offline
Please verify your thermostats are installed correctly , To test remove both and test the engine .I have seen em installed in-correctly ...Mine was
  #6
Old August 25th, 2009, 07:45 PM
It's really not likely looper thermostat assemblies are installed incorrectly since they will only fit one way. However, they must be there for the motor to operate properly with that cooling system. Again, we're assuming the motor is a 88 / 89 V4 looper with the stock water control valve in place. If it's been upgraded to the 93 style cooling system then that's a little different.
  #7
Old August 25th, 2009, 09:19 PM
Daviet Daviet is offline
Master Chief Petty Officer
What about a slight head gasket leak pressuring the cooling system and restricting water circulation? Just thinkin.
  #8
Old August 26th, 2009, 07:37 AM
kenmyfam's Avatar
kenmyfam kenmyfam is offline
The thermostats on mine are either in correctly, not in at all or you have broken something putting them in wrong.
Difficult to screw up.
Have you done a temperature test on the heads ???
__________________
1985 Doral 164 1985 140hp Johnson EZ loader single axle trailer all = a whole lot of family fun !!!!
Windsor Spitfires. Memorial Cup Champions 2009
  #9
Old August 26th, 2009, 09:51 AM
Be sure that the small holes in the thermostat cover and cover gasket are open, or the water control valve will not function properly. If they are both open, then it is likely that your water control valve needs to be serviced as Dhadley indicated.
  #10
Old August 26th, 2009, 10:22 AM
Thermostats are both new. and the definitely only go in one way. Engine runs at 140. except when there's low PSI,
T is in the line coming from the starboard bottom of the block in the line going into the valve behind the throttle.
seems to get 15psi if i idle it high (4000) at the dock. When moving, its at 5 and drops to 1,2 PSI when i speed up. if i slow down to a crawl it stays low. Only when I pop it in neutral for a couple of seconds do i regain above 5-10.
this is definitely a mystery to me. would the control valve be opening too much? causing very low pressure at the gauge?
  #11
Old August 31st, 2009, 06:37 PM
nymack66's Avatar
Assuming your pressure gauge is T in correctly then I will check the impeller you may have shared the key on it or broke off a blade and its slipping at the higher RPMS..
  #12
Old August 31st, 2009, 07:58 PM
kenmyfam's Avatar
How about a photo showing us all the water control valve and where the pressure gauge is teed into the system.
__________________
  #13
Old September 1st, 2009, 02:37 PM
I'll try and get a photo this weekend.
I have more information.
I got the engine up to temperature at the dock. than upped the RPMs to 5000. water pressure goes up to 20PSI. I let it run like this for 5 minutes. Pressure stayed at 20.
So now I'm totally lost. What would be different when I'm moving than when I'm at the dock?
  #14
Old September 1st, 2009, 08:47 PM
It's a wonder that you did not blow the engine up; you should never run a two stroke higher than 1500 RPM unless it is in gear.
According to the Teleflex chart, the pressure should be at 12-25 PSI at 5,000 RPM, but that will depend on where the pressure gauge is attached and if the line to the gauge is clear and free of water. The elbow at the adapter plate needs to be clear as well, and the Water Control Valve has to be functioning properly.
  #15
Old September 1st, 2009, 11:57 PM
kenmyfam's Avatar
How much motor is in the water when you are planing ???
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
50 hp evinrude cooling problem doc1213 Johnson & Evinrude Outboards 2 June 12th, 2005 11:44 AM
86-Evinrude 40 hp cooling problem? Skipmunk Johnson & Evinrude Outboards 9 May 25th, 2005 06:23 AM
cooling problem with 1.5 HP evinrude mikkel_kiilerich Johnson & Evinrude Outboards 2 February 11th, 2004 08:43 AM
9.9 Evinrude cooling problem william =robert1 Johnson & Evinrude Outboards 12 March 4th, 2003 05:51 PM
'52 Evinrude cooling problem fanoog Johnson & Evinrude Outboards 3 July 3rd, 2002 09:57 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
