  #1
Old August 24th, 2009, 07:15 PM
cnd cnd is offline
Exclamation Aluminum hull repair
I recently purchased a Fisher 180 Marsh Hawk and have no issues other than the boat takes on water at an alarming rate. I have followed all of the advice and have filled up the boat and found 1 crack about 6 inches above the keel. This crack is about 1.5" long. I also seem to have two other leaks under the keel beam. Is my best course of action to try jb weld or the stick epoxy? Will these last long term or am I just putting off the inevitable in having the keel welded the length of the boat and a patch welded over the crack? Please advise.
  #2
Old August 25th, 2009, 05:43 AM
5150abf's Avatar
5150abf 5150abf is offline
Default Re: Aluminum hull repair
being a welder myself I would have it welded, as you said JB or epoxy will hold for awhile but eventually you will have to do it again or get it welded so I would pony up now and do it right.
The problem is you can't weld the keel, there is almost always a rubber gasket or sealer under it and as soon as you start welding it melts and gets into the weld but I would say the keel leaks are from lose rivets and can just be rebucked, which you can do yourself.
__________________
GO IRISH!!!!
  #3
Old August 25th, 2009, 07:25 PM
AZcamperguy AZcamperguy is offline
On the other hand, jb weld and the like is cheap. Yeah, you will end up redoing it but it can buy you time to save the cash and still fish
__________________
Currently fishing out of a 14' tinny w/6hp Mercury.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum hull repair Floyd M Boat Restoration and Building 12 July 11th, 2009 12:33 AM
aluminum hull repair with pics boatruptcy Boat Restoration and Building 19 November 16th, 2008 07:20 PM
1992 Aluminum Boat needs a good cleaning of the Aluminum Hull What works best?? sigarmsp226 Boat Topics and Questions (not engine topics) 10 December 15th, 2007 07:35 AM
78 starcraft aluminum hull repair options? dex76 Boat Restoration and Building 9 August 17th, 2007 03:37 PM
The Best Way To Repair Aluminum Hull AJ168 Boat Restoration and Building 7 February 11th, 2006 12:29 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
