  #1
Old August 24th, 2009, 06:25 PM
capriwald capriwald is offline
Default 1983 bayliner capri/volvo aq125a/270
new here and have a few questions. Ill give as much info as i can to find an answer. I have a 1983 bayliner capri, with the volvo aq125a and 270 sterndrive. the boat was only firing on 2 cylanders when i bought it. figured out that a jet on the back carb was plugged. I cleaned that out and it started up and ran great. the next weekend on the lake it started bogging out when givin throttle. so i just went straight for a carb rebuild kit. rebuilt both carbs, with the help of my marine mechanic. now the boat is really a mess. its hard to get started and idling. it bogs down really bad with any gas. once you do get it running, its almost like half the time it runs on 2 cylanders and half the time on 4. if you go for a cruise and return to idle, one time it will idle nice and smooth but at 2000 rpm. the next time its a rough idle around 500. you really have to play with the throttle to even get the boat to WOT. sometimes it will also chug around and sputter once you turn the key to the off position. but not every time. I put new plugs in at the beggining of the year. timing is right on. put a new fuel water seperater filter on. new cap and rotor last year. im lost and so is my mechanic. we have tuned around with this thing and can get it running good at home but not on the lake. then tune around with it on the lake and it will run good for a minute and then go back to the same old thing. any ideas? thank you
  #2
Old August 24th, 2009, 10:52 PM
-JR- -JR- is offline
Default Re: 1983 bayliner capri/volvo aq125a/270
what kind of carb is it .is it the solex
  #3
Old August 24th, 2009, 11:34 PM
werthert werthert is online now
Well when you say it runs good when it's *not* on the lake it makes me think compression is bad because it has to work harder in he water.
Or...
Try some seafoam?
  #4
Old August 25th, 2009, 02:44 AM
BETZ954 BETZ954 is offline
i would check the compression first. i should be 142-170. an make sure you have a good idle, your idle speed should be 900rpm. also your max crusing speed should be bout 4800rpm. if you can get a fuel presser gauge hooked in it your feed pressure needs to be between 2-4 psi.
  #5
Old August 27th, 2009, 04:43 AM
Quote:
thats correct, well actually two of them. haha. I was also thinking the seafoam idea. Ill get the compression checked aswell. That makes sense to me aswell.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1983 bayliner capri AQ125 A Volvo rbethart Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 July 14th, 2008 10:47 PM
Exhaust manifold replacement for Volvo AQ125A 1983 bayliner capri eyezaiah Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 March 3rd, 2008 01:41 AM
What Prob For a 1983 Bayliner Capri aq125a Roncapri Prop Questions and Topics 2 July 22nd, 2007 10:19 PM
1983 bayliner capri AQ125 Volvo rbethart Bayliner Boats 1 August 30th, 2006 09:41 PM
RPM GUAGE VOLVO/Bayliner Capri 1983 eyezaiah Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 September 3rd, 2004 07:35 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
