  #1
Old August 24th, 2009, 11:13 AM
nightimefishn nightimefishn is offline
Default head gasket 197x Mercury 115 inline 6
I am wondering if someone can confirm something for me. I have a 78 or 79 mercury inline 6 115 HP with low compression on 4 (about 40 psi). All others have around 120. I am showing some milky substance around carb and plugs. So I had a mechanic come take a look. He is saying head gasket.
I am a little confused because I thought I have read that these didnt have head gaskets?
So two questions
1. Does the 1978 or 79 inline 6 have a head gasket
2. What causes head gasket to go, age? I do not think there is an overheat issue.
Thanks
  #2
Old August 24th, 2009, 11:48 AM
daveswaves's Avatar
daveswaves daveswaves is offline
Default Re: head gasket 197x Mercury 115 inline 6
So two questions
Thanks
Find another mechanic, there is no head gasket on the inline 6 merc,. You can inspect the piston for number 4 by removing the intake port cover that is in the center, each cover reveals two cyl. Likely the piston is damaged, you will be able to see how badly by removing the cover. Post a pic for more input.
__________________
Mercury inlines....nothing else stacks up
The answer to "do i need to change my water pump impeller" is YES
  #3
Old August 24th, 2009, 12:43 PM
Thanks Dave!
That's what I was afraid of. I am no mechanic by any means but such low compression on that cylinder is really bad right. Would it be worth a rebuild and if so how much should I expect to pay for such a job?
I will take some pictures as soon as I can.
  #4
Old August 24th, 2009, 12:50 PM
Chris1956 Chris1956 is offline
A single oversize piston+ring set is abut $100. Gaskets about $100. Boring a single cylinder about $50.
Labor to completely tear down the motor, and to reassemble is going to be $500-$1000. You also need to fix the cause of the damage, likely clean the carbs and adjust them, likely $250-500.
  #5
Old August 24th, 2009, 01:44 PM
So bad carbs could be the cause of this?
I am going crazy with this engine. It ran excellent for like 2 weeks then all hell broke loose!
I was originally having issues when I would be WOT for about 15 mins I would shut her down and then try and start her up it would just tick. So I inspected wiring harness, internal wiring harness was shot. So I have since replaced the harness along with several other corroded wires.
Engine starts just fine now but sounds like it is missing. Timing is dead on so then figured let me call someone to take a look. Guy came over did compression test and good compression on all but #3 and #4 like 45 psi. He said looks like a head gasket. After I heard him say that I started looking more on head gaskets. I remember reading that the inline 6 doesnt have a head gasket. Now I am at a total loss and extremely frustrated.
I had originally thought all was due to bad wiring harness, not so lucky I guess.....
Thanks for all your responses I am sure I will have some more questions over the next few days.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What head gasket does my mercury motor have?? snave0603 Mercury & Mariner Outboards 1 June 28th, 2009 09:50 PM
Mercury, 50hp-1980 Head Gasket jpriesjr0883 Mercury & Mariner Outboards 1 June 24th, 2009 10:58 AM
1999 mercury 25 hp runs Head gasket????? fishinjack Mercury & Mariner Outboards 2 October 9th, 2007 06:17 PM
Head Gasket at a Mercury Dealer? turtle1173 Force & Chrysler Outboards 2 August 14th, 2003 04:20 PM
Mercury Inline 6 115 HP Whole in head above Piston #1 Bry21317 Mercury & Mariner Outboards 4 April 25th, 2002 11:05 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
