  #1
Old August 24th, 2009, 12:31 AM
kencat kencat is offline
Default 88 Evinrude (Johnson OMC) 60hp 3cyl - Opinions on repair for damage in top cyl
Hi, I would like to get some experienced opinions on what kind of mimimum repair I can get away with to get my ole Evinrude running again. The motor has been in my family since new and so far has been good to us. It has seen about 4 years of storage until last summer when I decided to get her running again, but had a problem where it would not get up on plane. I put new carb kits in after thorough disassembly and cleaning in acetone, replaced all rubber fuel lines in motor, new remote gas tank, and replaced the VRO with a standard ole fuel pump and premix the gas. Also, prior to last outing, I put an older (79??) lower gearcase on with a rebuilt water pump, and pee-hole flow was strong
Ran great this summer initially, but started getting finicky at idle sometimes where it wanted to stall. Finally, over the past weekend, it decided to make a big backfire as I dropped off throttle after a high speed run and it died. It would run with the fast idle lever maxed out but sounded pretty nasty. Engine block was not hot, actually kind of cool which surprised me. Finished off the day on the lake putting around and fishing with the old trusty 15hp evinrude kicker.
Back at home, a compression check showed 45 psi on the top cylinder, with 102 and 110 on the others. I pulled the head off tonight and found what looks like the results of a fragmented piston ring. What I could see of the cylinder walls looked surprisingly good, just one area of a slight scape where there is damage to the piston edge and the top of a transfer port.
I have never encountered something like this before, but am not hesitant about learning what I need to to fix this myself as much as I can. I have an 86 Johnson parts motor that has a blown top end I picked up for the lower gearcase, and hoping it has a good head that I can use.
What do you all think is needed to fix this? I'm thinking new piston and rings, and hone the cylinder bore........given that I don't find anything bad in the crankshaft area. Some of the concerns I have is whether the slight scuffing on the cyl walls is too much, whether the small damage to the upper end of the transfer port will cause problems, and if the resulting compression of a repair would be too high relative to the two other cylinders. Also, are the rings on the other cylinders ready to fail soon as well?
Other questions:
(1) based on the picture of a fragment, is this a busted ring? wedge shaped piece?
(2) cause of damage? doesn't look like a lean condition or lack of oil or overheat.
(3) location of other fragments - do I need to tear down the exhaust pathways to clean out?
(4) other things I've missed?
Well, here are the pics -
  #2
Old August 24th, 2009, 07:46 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 88 Evinrude 60hp 3cyl - Opinions on repair for damage in top cyl
you are at a complete tear down, and replace pistion, etc.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1970? Evinrude 60HP 3cyl Ignition problems mustman65 Johnson & Evinrude Outboards 6 January 5th, 2009 08:07 PM
IL6, opinions on what to do with it, w/pic of damage ziggy Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 13 June 2nd, 2006 09:43 PM
any damage done? 3cyl laker925 Mercury & Mariner Outboards 1 July 24th, 2005 02:02 PM
71 mod.60hp evinrude spark1 out 3cyl Rigby Johnson & Evinrude Outboards 0 September 4th, 2004 01:24 AM
1990 3cyl Evinrude 60hp with VRO LesW Johnson & Evinrude Outboards 4 June 12th, 2003 09:04 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
