These aren't trailer tires are they?
My trailer tires tell me to put in 40 pounds but at 40 pounds they still look low. Should I add more or just leave it be if thats what the tire says to put in it. Not sure if you should add any more or any less.
what's the max weight on the tires, and how much does the trailer weigh?
A 19 footer with a single axle trailer is pretty heavy.
They should be at least load range C 1760 pound rating at 50 psi...
Never seen trailer tires that called for 40 psi...
A 70 series trailer tire?running 185/70/13 tandam 50psi max
