  #1
Old August 23rd, 2009, 01:50 AM
soreloser soreloser is offline
Default Taking on Water??
New to boating, own a 96 SEI174. After a day of skiiing and tubing etc, seems to be a lot of water run out of the boat with the plug pulled leaving the launch? Ran the bilge a few times, but must not be deep enough to pump out. What looks like litres, probably isn't. How much water should be in there anyway? Where would the water be coming from? Thanks for the help, much appreciated.
  #2
Old August 24th, 2009, 12:43 AM
Default Re: Taking on Water??
Ok, so i filled the bilge with the garden hose today. A small trickle of water at the bottom the the drive where it meets the hull on both sides. Questions:
1-How serious is this?
2-Can I seal with a silicone type sealant? any risk?
3-If I was to have repaired, how bad is it?
Thanks for any help or answers.
  #3
Old August 25th, 2009, 04:01 PM
gprince's Avatar
gprince gprince is offline
Soreloser,
Seems like you should take it and get it repaired by a professional however, 3M makes a product called "5200 - Above / Below the water line sealant". If you can pinpoint the exact area like you have said, it might be worth a shot to see if you can seal it.
Good luck!
__________________
2006 Larson 208 LXi
5.0 MPI Alpha 1
Nautic Smart Tabs
Tow Vehicle: 2007 Tundra Crewmax 4X4
  #4
Old August 27th, 2009, 11:00 AM
Thanks, took it to the shop, motor and leg off, then seal up transom. Put it all back together. Tough first lesson to learn, but that's how it goes.
  #5
Old August 28th, 2009, 01:08 PM
rokrau rokrau is offline
Do you mind telling us about how much that set you back?
Or did you end up doing it yourself? I think I might have a similar issue on my 2001 180 SEI, allthough I haven't filled the bilge with water yet.
__________________
Mast- und Schotbruch und stets eine Handbreit Wasser unterm Kiel!
  #6
Old August 28th, 2009, 11:15 PM
Quote was for about 9hrs labour and the gasket....still in the shop, will let you know. I expect about $1000 + or -.
  #7
Old August 29th, 2009, 12:03 PM
leoo24 leoo24 is offline
wow 1k! my mechanic charges at €35 the hour, at 10 hours that would only be €350, 1k seems a little steep
__________________
2001 crownline br 205
4.3 EFI mercruiser
  #8
Old August 30th, 2009, 01:10 AM
Only 2 shops in town, shop rate is $90/hr. I haven't found a private mechanic yet as I am new to the boating community. Hope to find one soon.
  #9
Old August 30th, 2009, 07:44 AM
wow, i wonder if boat mechanis are more expensive in general over there in the states? i'm in spain and "my mechanic" isn't a private guy, he's from a local boat dealer, a few here get up to €45 an hour but no more.
__________________
4.3 EFI mercruiser
  #10
Old September 1st, 2009, 02:40 AM
In Canada, smaller town in British Columbia.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
taking on water McJaggr Boat Topics and Questions (not engine topics) 7 July 15th, 2009 01:30 PM
Taking on Water FishHog Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 May 5th, 2008 09:41 AM
Taking on water Helstrm Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 August 10th, 2005 09:39 AM
Help! Taking on Water! hckrphil Boat Topics and Questions (not engine topics) 21 August 23rd, 2004 01:42 AM
OMC taking in water! blckjck30 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 August 6th, 2003 11:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
