Re: 2000 90 YAMAHA Lower unit gear lube black and burned smelling
use the mercruiser high performance (green stuff) in it and see if your problems return.
__________________
just because you found it that way... doesn't mean it's supposed to be that way.
Part of diagnostics is spending time figuring out not only what the problem is, but also sorting through what it isn't.
The older the engine is, the chances of it having more than 1 problem goes up exponentially
Boating has always been a rich mans hobby. Buying a new boat gets cheaper every year, but the maintenance, the repairs, and the overall cost of ownership of a boat has never gotten any cheaper.
