  #1
Old August 22nd, 2009, 06:11 PM
mandyman1345 mandyman1345 is offline
Default 1989 70hp evinrude high rpms
I recently took out the boat and as I was going across the lake then I believe that it is the over heat horn went off and shut the engine down. I started it back up and it started and would only run at 1500 to 2000 rpms as it states in the manuel to protect the engine. At first I thought maybe I got into some weeds, but I was in the middle of the lake at the time. I put it in reverse to clear out any thing in the intake filters. I slowly got back to the dock and then brought it to a local repair shop. I got it back and they stated that they could not find anything wrong. The horn was working fine and they did a compr check and said it was okay. I took it back out to the lake and now the rpms at idle are just under 2000rpms and at full throttle it is at just under 8000 which is as high as the gauge will go. The engine seems to be running fine. It has a slight rough idle which it has had. The engine seems to sound fine except the tack is slowing 2000 rpms more than it should at any speed. What I am trying to say is that when I am at full throttle it shows just under 8000 rpms the engine sounds fine and not sounding like it could blow at any moment. Any suggestion would be appreciated.
  #2
Old August 22nd, 2009, 06:18 PM
pmat1's Avatar
pmat1 pmat1 is offline
Default Re: 1989 70hp evinrude high rpms
The WOT for that engine is 6500; your tach may be off.
__________________
1986 Thundercraft 162SS Regency
1985 Evinrude 70hp
  #3
Old August 22nd, 2009, 06:25 PM
Thats what I was thinking. As the engine has got older I have notice the rpms have gone up on the tack with no notice of engine sound going up.
  #4
Old August 22nd, 2009, 06:28 PM
Daviet Daviet is offline
Master Chief Petty Officer
Do you have access to a hand held tac? Maybe the shop that checked out your engine has one? You could compare the two and see if your tac shelled out on you.
  #5
Old August 22nd, 2009, 06:29 PM
pmat1's Avatar
Definitley check the tach, 8000 and the engine would surely not last long.
As for it not running right, wait for the pros respond, im little help.
__________________
1985 Evinrude 70hp
  #6
Old August 22nd, 2009, 06:35 PM
Thanks petty Officer.
  #7
Old August 22nd, 2009, 06:36 PM
Thanks again pmat1.
  #8
Old August 23rd, 2009, 03:51 PM
Anybody else have any input on the high rpms or the reason that the overheat alarm went off. I did notice that the motor is pumping water at a solid flow except in the past it was stronger to the touch.
  #9
Old August 23rd, 2009, 10:14 PM
Could you have wrapped something around the intake on the lower unit that fell off when you stopped. Just thinkin.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1989 Evinrude cuts off at high rpms lof54 Johnson & Evinrude Outboards 5 April 25th, 2009 07:21 AM
1986 9.9 Evinrude dies out at high RPMs wheresthefish Johnson & Evinrude Outboards 5 December 22nd, 2008 07:53 PM
1977 55hp Evinrude is bogging down at high RPMs ? 103Control Johnson & Evinrude Outboards 6 July 26th, 2006 10:14 PM
1989 evinrude 225 wot rpms/prop cornholio Johnson & Evinrude Outboards 6 October 21st, 2005 09:37 AM
Evinrude 70hp 1989 High temp alarm Greg Holmes Johnson & Evinrude Outboards 13 January 9th, 2003 02:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
