oil leak
I have a 1992 Rinker 181 and i went to check the oil in the outdrive and there was none. So i went to fill it up, from bottom up, and the oil started to come out the (weep holes). The small holes on both sides of the lower unit. I replaced the o ring between the upper and lower unit and still leaks. Thank for any help.
