Re: Adding a tilt / trim gauge
the gauges arent all that cheap, but it can be done fairly easily. gauge location and mounting will prob. be the hardest part. The outdrive is probably wired for the gauge already. Mine is, i just havent put a gauge on it yet. You might even have the wire run all the way under the dash already from the factory, as the gauge is usually an option.
