While idling on muffs, should their be equal amounts of exhaust and water coming from both sides of the bottom outdrive?
It is lacking WOT RPMS by a few hundred, and I just thought of this. I replaced the exhuast flapper when I changed the engine b/c it was burnt up from a bad impeller. The pictures shows what I am talking about.
Maybe I have some rubber stuck? If this could be a problem, can I pull the riser and blow compressed air back up the outdrive?
3.0 Mercruiser w/ Alpha one
