  #1
Old August 19th, 2009, 10:52 PM
fishbasket fishbasket is offline
Default 69 evinrude shift solenoid pictures
does anyone out there have the diagram (or can you email me) from the original owners manual on how to install the bottom part of the shift solenoid into the (i believe its the oil pump) is there something that holds the bottom of the shift solenoid in place>
i had a 70' hydro electric lower unit johnson 60hp with stripped gears and dog. 60esl70b
i replaced lower unit with 69' evinrude hydro electric 55hp 55973a
it was shifting fine with 60hp lower unit f/n/r but thunking due to worn gears and dog
now with the 69' evinrue lower end on, its stuck in forward
i put the shift solenoid assembly from the 70' in the 69' gearcase
but im not sure how the bottom of the assembly goes in. do i have to take out the oil pump does it attach to the back of the oil pump behind the forward gear>>? please help
still frustrated
fishbasket
  #2
Old August 19th, 2009, 11:11 PM
frosty42 frosty42 is offline
Default Re: 69 evinrude shift solenoid pictures
I don't have pictures, but I have a 55 hydro-electric. I'm having issues as well but I do know the shift valve (plunger) has a ball end that is held in a plastic clip, attached to the end of the shift rod. On the 68 & 69 55hp the plunger goes directly into a port of the pump...just slides straight down in
  #3
Old August 19th, 2009, 11:17 PM
are these two lower units even compatible i do hear a click with the engine off and i direct wire 12V from battery to green wire could oil pump be stuck do i have to take off pinion gear to get forward gear out to get to oil pump>?
any help appreciated.
is that solenoid assembly for sale?
  #4
Old August 19th, 2009, 11:33 PM
F_R F_R is offline
The oil pump and solenoids are very different between the 1969 and 1970. You can't use the '70 solenoids in a '69 oil pump if I am umderstand that's what you are trying to do. It just doesn't work that way.
If you are thinking of swapping the oil pump from one to the other, I don't know if that is possible or not--never tried it. But to answer your question, the oil pump is the last part to come out of the case and the first part to go back in. It takes a huge honkin' snap ring pliers with special extensions to get the pump retaining ring out and back in.
  #5
Old August 20th, 2009, 07:28 AM
sorry, i missed that you were trying to exchange 70 parts into your 69. the pic I posted is for a 68 or 69 only. (and sorry it's not for sale, I just happen to be working on mine.) 70 shift rod is for sure different. On 70 model the shift rod does not go directly into pump as in the 68 & 69.
If your hearing a click (light click with power to green, then additional click when applying power to blue while still appling power to green) the solenoids would appear to be working.
Note, wrong oil will make it not shift out of forward, must be type c or premium
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude shift solenoid question jumanjii1 Johnson & Evinrude Outboards 3 May 28th, 2009 06:21 AM
evinrude shift solenoid and shift switch downjigger Johnson & Evinrude Outboards 8 May 21st, 2009 06:49 AM
Evinrude shift solenoid question jumanjii1 Johnson & Evinrude Outboards 0 May 21st, 2009 05:45 AM
'69 evinrude shift and solenoid redneckyaghtclub Johnson & Evinrude Outboards 3 August 16th, 2008 05:38 AM
1971 Evinrude 125 hp shift solenoid HELP jimbat10 Johnson & Evinrude Outboards 4 August 1st, 2008 12:59 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
