I have a 1972 mercruiser 165 I recently replaced my 37yr old gauges with new ones. In the process I replaced my ammeter with a voltmeter. while doing this I changed my wriring slightly from factory. I now have battery power to my key and then from there the guages and accessories (bilge,blower, wipers etc) run of the ignition terminal of the key switch. From this same terminal a lead goes to my volt meter were it connects with the altenator lead from the factory harness. I am wondering if something I did could have killed my altenator as it died right after I made the change. after taking it apart it apears my diode trio is burned up. (it is a delco remy with internal voltage regulator) Thoughts any one? I dont want to burn up the replacement. Thanks
