turfguy1969
- Jul 17, 2008
- 19
I have two questions. First, i am having rich/black smoke issues at idle and fouling plugs. I have a 2000 5.7L EFI mercruiser.
#1. I am trying to check timing. I have a marine code reader and have set the engine in base timing mode. I have aimed the timing light at the proper spot and have found only a VEE notch with no incremental degree rating. The timing dash lines up to the starboard of the vee. How do I know that this is 8 degrees btdc where it is supposed to be? Did they set up this engine to line up with the notch? I have NO numbers to reference?? I hate to just move the distributor without a baseline.
#2 When i mechanically move the throttle into a position past idle, maybe 20% of total, the throttle revs past 3000 and feels like it would keep going up like the Throttle position sensor is not working properly. I read that a malfunctioning TPS will mess with idle and could be causing fouled plugs/black smoke?
I just changed distributor, ignition sensor, and rotor.
thanks
thanks
