  #1
Old August 19th, 2009, 07:28 PM
cbedd cbedd is offline
Unhappy Help With 20' Pontoon Prop/speed
I have a 20' pontoon boat with a mercury 50hp bigfoot 2002, It came with a 14dia by 13 p prop. The mercury web site says that the motor should run at max5500-6000rpm, the most we can get at full throttle is 4200rpm and top speed 15. We were told to use a 14x10 pitch to get the rpm's up. So we put one on and we now are getting at 15mph the rpm's are 5500 but we still have more throttle if we increase the throttle speed it will go over 6000rpm , not recommended by manufacture. What can we do to have max rpms 5500-6000
with full throttle , and will this give us any more speed. Any info please.
  #2
Old August 19th, 2009, 08:46 PM
steelespike steelespike is offline
Default Re: Help With 20' Pontoon Prop/speed
You should really put this in the prop section.I think a 13 would normally be pretty close for a big foot.Are you sure your getting full throttle?Are the tubes clean and prop in excellent shape.How is the compression.
Is the speed by gps:much more accurate than a speedo.I think your setup with a 12 or 13 should get about 18 to 22 mph. and about 5,500 rpm.Is the motor running on all cylinders?
  #3
Old August 19th, 2009, 10:30 PM
Silvertip Silvertip is offline
14x11P four blade pontoon prop is pretty standard for the 40/50/60 big foot motors. If the props you've tried are Mercury props thats one thing. But you need to understand that (for example) a 14 x 10 prop from two different manufacturers will very likely perform differently. The reason is the prop "design". One prop may have more rake than the other, the blade shape may be different, and the amount of cupping may be different to name just a couple of features. Pontoon props have very large, more rounded blades which provides more thrust, especially in reverse for docking manuevers. It is the prop that puts the observed WOT rpm in the manufacturers recommended band. Speed will be whatever that prop provides. More pitch than that lugs the engine and less pitch than that causes over reving.
  #4
Old August 20th, 2009, 12:35 PM
Yes I have full throttle the tubes and prop are in great shape. The motor is near new and runs perfect. The speed is by speedo, today we are taking out our gps to get a speed reading. Thanks.
  #5
Old August 20th, 2009, 12:41 PM
Quote:
The prop that came with the boat we think is mercruy, The 14-10p is after market and it does have larger more rounded blades. We can buy a 14-11p used for $100. do you think that well bring up the rpm's to were they should be at full throttle. Also the prop shop said that if we take the 14-13p that came on the boat and change to dia from 14 down to 13 3/4 it may help with the rpm issue and still give us the push we need.
  #6
Old August 20th, 2009, 03:29 PM
As suggested eariler the 11P prop should put the engine in the proper rpm range and is a very common prop for that series of engines. I think you will find that using GPS your speed is a little faster than you are seeing on the pitot speedometer. Those don't start registering until boat speed is somewhere around 10 mph.
Keep in mind that when you play with propellers trying to get rpm up or down, that boat speed does not necessarily increase or decrease significantly even though rpm may change significantly. That because of the distance a prop moves forward with each revolution of the engine. Just using your numbers for example, the 13P prop results in a "theoretical" forward movement of 13 inches with each engine revolution and with that prop you observed 15 mph at 4200 rpm. To force the engine up into its recommended band you switched to a 10P prop so the movement is now only 10 inches (theoretically) with each rev. So to achieve the same 15 MPH speed the engine now needs to rev to something over 6000 (again your number). So the increased rpm and the same speed is to compensate for the less forward movement provided by the prop with less pitch. The effect is the same as shifting down or up a gear in a car.
  #7
Old August 20th, 2009, 08:21 PM
Thanks for the info, went out today with my gps and with the 14-10p prop at 5500 rpm we were doing 26km which is around 15mph so my speedo is accurate. At 5500 rpm I still had alot of throttle left. I think I will buy a 11p prop as suggested. What's another $100 , what is it they say about owning a boat????
  #8
Old August 20th, 2009, 11:24 PM
Jeep Man Jeep Man is offline
Silvertip, I have a 60 Bigfoot. I'm not familiar with a 4 blade being standard. Mine is a 14x11 three blade and I am going to a 14x9 to get the WOT rpms into the proper band. Am I going with the wrong one?
__________________
I've fished for half of my life, the rest I just wasted.
  #9
Old August 20th, 2009, 11:35 PM
Cbedd, where are you located. When you said KPH I figured your north of the border. THE reason for my asking is that there was an ad in July on Kijiji London for a 14x11 Bigfoot prop for $40. I have the guys email address if you need it.
__________________
  #10
Old August 20th, 2009, 11:45 PM
Just to add a point of clarification -- there is no "standard" prop for most outboards. They are shipped from the factory without them for the simple reason that the manufacturer has no idea what boat the engine will be installed on. As you are finding out, certain boats require a specific prop to operate properly. That's why prop selection is such a crap shoot. There is no "one size fits all" in this regard.
  #11
Old August 21st, 2009, 01:21 PM
Quote:
I live in Salmon Arm BC Can. Thanks anyway for the info
  #12
Old August 21st, 2009, 01:23 PM
What is the motor on a pontoon and if so how big?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Pontoon Speed Help JonathanEngr Pontoons 38 July 22nd, 2009 07:28 PM
pontoon top speed boatradioman Pontoons 13 June 27th, 2008 01:32 AM
Speed with a 90hp on pontoon flipjoe Pontoons 8 June 23rd, 2008 06:24 AM
Pontoon Speed John avery Boat Topics and Questions (not engine topics) 24 December 8th, 2002 05:57 PM
pontoon speed oaker 1 Mercury & Mariner Outboards 1 May 3rd, 2002 07:31 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
