  #1
Old August 19th, 2009, 06:22 AM
karlt5503 karlt5503 is offline
Default Do I need a wakeboard tower?
Wanted to get some advice from those that have wakeboarded with and without a tower. I have a used Crownline and have been pulling from the transom. I was debating on installing a tower, but wondered how much of a difference it would make. Can you get a lot more air with a tower from a normal I/O? Its not putting off a huge wake like a wakeborad boat would anyway.
Thanks for any input.
__________________
97 Crownline
5.7 235hp
18ft
  #2
Old August 19th, 2009, 03:34 PM
ryland43 ryland43 is offline
Default Re: Do I need a wakeboard tower?
a tower and some fat sacs would make a big difference, towing from the transom is good for beginning but a tower will help you improve. id get a cheap one and try it out.
  #3
Old August 19th, 2009, 04:49 PM
xjcj3a xjcj3a is offline
you can make a pylon for 50 bucks or so. try that and see if you like it.
  #4
Old August 20th, 2009, 11:39 AM
Tabes117's Avatar
Tabes117 Tabes117 is offline
The tower is pulling you up and out of the water, because of the height. None of my friends have a tower. They say its easier to get up on my boat.
__________________
2005 Ebbtide 2300, 6.2mpi with bravo 1
  #5
Old August 20th, 2009, 11:42 AM
RoyR's Avatar
RoyR RoyR is offline
Nope, seen guys doing stupid tricks with no tower, but I think it will make learning easier. 50 million wake boarding kids can't be wrong....
__________________
Roy R
Maxum 1900SR, 2002
Life is a matter of risk and the chances of success are in no way enhanced by extreme caution...
  #6
Old August 20th, 2009, 02:47 PM
PitchFork's Avatar
PitchFork PitchFork is offline
Have done both behind my boat and much prefer to wakeboard behind it when i installed the tower last winter. The pull out of the water is much easier and it seems to help with jumping wake 2 wake. It also gets the boards off the floor and out of the way. The tower speakers also gives the rider tunes to listen to while they are riding.
__________________
1994 19' Chaparral 1930SST Bowrider 5.0L 4bbl Rochester
  #7
Old August 20th, 2009, 04:46 PM
salty87 salty87 is offline
you def. don't NEED one but life is much better with a tower.
just riding in a straight line is easier on the lower back. you're constantly working against the downward pull of a rope tied down low. with a pole or tower, you can stand taller and rotate your shoulders back/push your chest out easier....better form, less soreness.
  #8
Old August 24th, 2009, 04:49 PM
Thanks for the advice everyone. It seems like it would obviously be better pulling from a tower since it is pulling you up. I just wondered how much of a difference it would make. If a tower wasnt so expensive I'd just slap one on and find out, but wanted to see if it was worth the money first.
xjcj3a - How do you make a cheap pylon? I dont want to put a hole in the floor of my boat, if that is required. Is there no way to attach an extension to the transom tow hook? Just to get a few feet. Seems like that would be a cheap way to raise the angle a little.
Thanks
__________________
97 Crownline
5.7 235hp
18ft
  #9
Old August 24th, 2009, 05:55 PM
http://forums.iboats.com/showthread.php?t=197986
read that thread over. if you just added onto the transom eye, when you pulled on it it would put alot of force on that eye. you could also go with a ski pole and add that to your boat. but its not as cheap as that diy pylon.
  #10
Old August 24th, 2009, 09:06 PM
smitty1258 smitty1258 is offline
+1 for the diy pylon.
still using mine. works great.
__________________
2009 Centurion Falcon V Air Warrior
NorthWest Ohio WakeBoarders!
www.maumeewake.com
  #11
Old August 28th, 2009, 05:33 PM
duster22 duster22 is offline
You hold longer in the air with a tower since its higher up.
  #12
Old September 7th, 2009, 08:39 PM
bemdur bemdur is offline
I needed to get my kid boarding with minimal investment. I had a tow tripod already in place on a 18' 90HP OB center cockpit fish boat. Using chain link fence post and hardware I threw it together for about $50. Four cargo hold downs give it most of the support and then a heavy cargo strap goes to forward cleats. I will try to attach a photo. We have been suing this for two years. It is absolutely rigid and handles me as a 190 lb beginner.
The wake is small but he can jump wake to wake on a 75' line. Flooding the fish lockers does not help build the wake. Having three humdred pounds of friends onboard seems to help. I read in a link here today adding bow weight helps. That would confirm the 300 lbs of freinds helping.
Often the wake is rounded. Any suggestions getting is steeper would be appreciated.
  #13
Old September 7th, 2009, 11:10 PM
adding weight to the front of your OB or I/O will make a bigger wake. If you add more weight to the back of the boat in addition you will get a firmer wake with a nice lip.
__________________
www.maumeewake.com
  #14
Old September 7th, 2009, 11:55 PM
Thanks for the info. How about safety? I think my boat can carry 1200 lbs of of gear and passengers. It is an 18 CC with a 90 HP. THe motor probably is 300 and I think is part of the count. Fuel is 20 gallons at around 6 lbs each I think for another 120. Figure another 200 for boat crap, beer and boards. This is 620 so far. I'm 190 and figure a passenger at 220. THis gets up to near capacity . Now lets add a pipe tower and pull a boarder from about 8' above water level. Are we at the limit of safety? I have been doing this for two years and it handles very well and turns fine.
So how much weight should I add and what type? I am thinking a bladder on the floor in front of the console. (actually four five gallon jugs to keep cost down)It would be low and forward. 20 gallons of water should be around 160 lbs.
We would be satisfied to just get a better formed wake that would give a pop.
  #15
Old September 9th, 2009, 12:03 AM
do you have a ski locker?
__________________
www.maumeewake.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
wakeboard tower Kevin215 Wakeboarding 4 September 15th, 2009 03:32 PM
wakeboard tower mandelcz71 Wakeboarding 4 July 26th, 2008 10:36 PM
Wakeboard Tower followme21 Wakeboarding 4 May 23rd, 2008 06:06 AM
wakeboard tower Bannerboy Sea Ray Boats 0 April 15th, 2008 02:02 AM
Wakeboard tower trweber Boat Restoration and Building 0 June 19th, 2004 07:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
