  #1
Old August 19th, 2009, 12:52 AM
Marlinman10 Marlinman10 is offline
Default 1995 Yamaha 85 fouling plugs
After about 25 hours on a set a plugs they will foul while trolling. I fish off shore here and do a lot of trolling at 1800 Rpm. should this engine be able to troll all day without this happening? I just got it back from the shop and they said it checks out other than doing a de-carb. I'll have it out this weekend and try again. I use Yamalube at 50-1 mix. Also it only turns 4000 rpm at WOT with a 17 in pitch prop. This seems low. It's on a 17 foot Glasspar that weighs 1100 pounds. I need a expert opinion. Thank You
  #2
Old August 19th, 2009, 08:38 AM
robert graham robert graham is offline
Smile Re: 1995 Yamaha 85 fouling plugs
the correct prop should allow for a WOT of 4500RPM to 5500RPM...could be the prop is the problem, but was it running better/different before this plug fowling started? is your thermostat allowing engine to get to normal operating temperature? if not, it could give you that rich mixture and fowled plugs. I run a 90C premix motor and can idle all day at any RPM without fowling plugs. I do run the Pennzoil Marine 100% Synthetic oil(Walmart $27/gallon) and it runs very clean with little smoke. if your motor was running good before in the 4500 to 5500RPM range then maybe an engine temperature issue. Hope this is helpful and Good Luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 8hp fouling plugs robn Yamaha & Suzuki Outboards 1 July 19th, 2008 04:26 PM
99 yamaha 225 fouling plugs sfd971 Yamaha & Suzuki Outboards 0 September 2nd, 2007 12:02 AM
'91 Yamaha 130 HP Fouling plugs Gr8NW Yamaha & Suzuki Outboards 1 September 6th, 2006 07:21 AM
yamaha 115 fouling plugs formula233 Yamaha & Suzuki Outboards 5 April 23rd, 2006 04:31 AM
yamaha 115 fouling plugs formula233 Non-Repair Outboard Discussions 2 April 22nd, 2006 04:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
