Re: Replacing the floor on my 18' Gruman GSF
Hey Boomertony....Your in the right place....welcome...I am currently in my first rebuild as well and found alot of usefull info and suggestions here .I came across a deal on a 88' 17' blue fin she is aluminum and I knew it had a few soft spots in the floor when I got her. Now it is totally gutted out wiring and all. This forum will be able to help you through anything you need to know.When you have a chance post some pics so we can see what you got going on.This also helps the guys who are better at these resto's to better help you out. With my boat I took up the carpet to find alot more damage than I thought. Then the old deck came out too find all the foam water logged and rotting the underside of the deck. So the deck and foam came out. While doing this I seen the wiring was a hacked up mess......out with that too.....LOL...If it was me doing it again I would do the same thing as I just did. Take out the deck, Check the foam by taking samples,Take a good look at the transom....And ask for help on here if you need it and keep on reading these forums...Good luck and shout back, someone will help you out.
