Here is the just of it.
Basstender 10.2 - 10' Plastic semi tri-hull boat
'73 Evinrude 6hp
worked on it for a month but could not get RPM's above 2K (if that fast) Did everything in reason to motor. Some things 2 times.
On Recommendation from here - Changed Prop to 8x5p
Motor runs up quick, rpm good and boat moves 2x faster (8mph)
Now: The original 2 blade 8x8p prop looked really bad. Pitted, hammered, cracked on one blade and possibly twisted or bent.
What I am wondering is if the prop itself was the cause of all the issues? The boat mfg. recommends 7hp Max so the basic 6hp should perform @ under 50% max load.
My Question now is.......... Was it the Boat/Prop pitch causing low rpm and no speed(4mph max) or was it possible the Prop damage causing loss of power?
Can a 2 blade prop cause enough turbulence as to kill RPM and forward movement?
I am happy that it is running better than when I began but I would love to be able to get more speed out of it without killing the RPMs again.
My only alternatives to the prop I now have are a 8x7.25p or 8x8p prop?
Any recommendations, theories, thoughts?
'73 Evinrude 6hp
