  #1
Old August 18th, 2009, 12:24 PM
scubaclay scubaclay is offline
Default Pontoon decking leaking???
Hey everyone, i have been searching and i cant find an answer for this anywhere. I just bought a 2007 24' Bentley and i have water coming up through the floor when im cruising. It bubbles under the carpet and looks like my boat is slowly peeing itself and spreads over the whole deck. It happens in the center of the boat on the 3rd seam of the decking. I have siliconed the rib underneath and tightened the screws on the rib to the deck but i am still getting a lot of water in. Does anyone have any ideas or suggestions? Should i try and build a splash guard for the ribbing underneath. Has anyone ever had this problem before?
Clay
  #2
Old August 18th, 2009, 10:46 PM
Jeep Man Jeep Man is offline
Default Re: Pontoon decking leaking???
IMO the only way water could be getting in would be through the seams between the plywood sheets which make up the deck. The water would be splashing up from the pontoons, which would be normal. Water penetration would not be. You could take up the carpet and deck and reseal all of it, but I would go a different route. There are previous posts (with photos) where other owners have plated in the underside of the deck to streamline the boat somewhat, reducing drag from water splashing against the ribs. This would improve your boat and fix your leaking at the same time, and less work than removing everything from the top.
__________________
I've fished for half of my life, the rest I just wasted.
  #3
Old August 19th, 2009, 05:42 AM
5150abf's Avatar
5150abf 5150abf is offline
Generally on pontoons the seems are on top of the crossmembers so I would make sure the screws or bolts haven't worked loose, yo shouldn't be getting water like that.
The deck on a toon is a major structural element, if yours is loose it will wear out alot faster so ccheck to make sure your deck is fastened to the crossmemvers still.
__________________
GO IRISH!!!!
  #4
Old August 19th, 2009, 09:53 AM
lowell7963 lowell7963 is offline
Send a message via Yahoo to lowell7963
You must be having excessive splashing under the boat, even if the seams were leaking. Have a qualified other person, drive the boat and look under it to see what the water is doing. I looked under mine and no water was spraying up on the deck under normal conditions.
Are you in hte ocean or where the wind is making large waves?
The other question is are you planed up properly, so that the tubes are level or the front is slightly raised. I am assuming you know that by raising the motor appropriately the front of the pontoon will raise, and reduce some splashing/spray.
__________________
Safe Passage
  #5
Old August 19th, 2009, 04:16 PM
thanks for your replies:
I checked the decking and the structure underneath and had to tighten quite a bit of bolts. I noticed some nuts were missing so i replaced all those. I had an aluminum splash shield fabricated to deflect water from that area. I never take it in salt water and the lakes i use are very calm lakes with relatively small waves. I am going to recaulk / seal the area and install that splash shield and test it out. I will let you guys know how it works out.
Clay
  #6
Old August 21st, 2009, 08:37 AM
bruuuuce bruuuuce is offline
Under skin the pontoon, that will solve that.
Also if your Bentley is like mine on the cross members they have splash shields on the braces, one of mine is missing and that is where I get splash up through the carpet, bet yours is the same way.
  #7
Old August 24th, 2009, 09:37 AM
thanks for all of your suggestions, took it out this weekend and problem is solved! I tightened all the nuts and bolts on the structure underneath. Some were very loose and some were just plain missing nuts. I used a maringe grade sealant on the rib that was leaking on the front and the back and i had a piece of 18 gauge aluminum bent into a splash shield. mounted that on the rib at the seam. no more leaking!!! Thanks again for all the suggestions!!
  #8
Old August 24th, 2009, 04:47 PM
rentprop1 rentprop1 is offline
I notice on mine that it will state as a small wet area then get bigger, it just looks like someone spilled water in the size of a quarter on the deck, then get bigger as we run, what I found was one of the T- style nuts has pulled down into the wood decking and thats where the water was entering from.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
pontoon decking MichaelMullis Boat Restoration and Building 7 August 4th, 2009 03:55 PM
Pontoon Boat - Water Glide 3rd Pontoon martybhawk Pontoons 7 July 13th, 2008 11:09 AM
replacing decking on 24 ft pontoon boat playme1979 Boat Restoration and Building 1 April 2nd, 2008 05:52 AM
Need Opinion For New Decking Pontoon shorty28 Boat Restoration and Building 7 April 18th, 2004 09:48 AM
leaking front chamber on 18' pontoon vonfranken Boat Topics and Questions (not engine topics) 2 October 2nd, 2003 09:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
