BTW, this is an XR4, not a XR2. Don't know what I was thinking there.
I changed out the lower gear oil today. Had a problem with the pump drawing in some air while pumping. I tested it out with water when I cleaned it out later and it worked fine. Maybe it was the thicker oil causing the pump seals to fail.
Don't know what oil they used in there before but it's got the high performance gear oil in there now. The new washer took care of the slow leak from the drain plug as well. I decided to hold off on the new impeller and thermostats until winter, or until I run the engine a bit and see if it's overheating at all. I did pull the thermostats to inspect them and the rubber gaskets seemed OK.
The prop hub diameter is 4-1/4". It's a stainless 4 blade, almost 6" deep and 13-1/2" diameter.
Here's a picture of the sticker on the lower unit. You would think it would come off in the water.
