Re: In Boards & Out Boards Advantages & Dissadvantages?
As far as outboard vs I/O... well, speaking from the I/O side of it they are much cheaper and easier to work on and modify/hot rod... alot of it transfers over from autos. Also when we're talking v8 I/O's the low end tq is much more then that of outboards.
I have to disagree about being "cheaper" to work on than an outboard... While most I/O's use some sort of "car" style engine that has been made for marine use, I/O's have tons of very expensive parts on them that go bad, (EX. manifolds, bellows, u-joints, gimballs, housing seals, regular stuff that goes bad like, water pumps, alternators, belts, etc.)
plus all the same stuff that goes bad on outboards (impellers, lower unit gears, ignition parts, etc.)
I'll grant you in some ways they are "easier" to "hot rod" as you have said because they are more like a car engine, but I for one would never, ever, own another I/O again as long as I have a boat... nothing but headaches, especially if you plan on using it in saltwater... doesnt matter how good you flush it out, you'll be replacing your EX. Manifolds every 4-5 years.
That being said, yes there's lots of information on all the differences.
I/O can use regular gas, if you are good at working on car engines, would be easy for you to adapt to the I/O for repair, they are a bit heavier if you start getting into the Big V-8's. Typically they are more maintenance and more expensive to repair than an O/B. You also have to do regular oil changes on them just like a car engine. They do develop a good bit of power, and you dont have the engine in the way on the back of the boat.
Outboards: 2-Stroke you have to mix the gas/oil every time unless you have a VRO style which injects the oil for you, but there is the additional expense of buying 2stroke oil constantly, but they are very light, develop a lot of power for their size, (if a bit noisy).
4-stroke works like a car engine, where the oil is kept seperate, and lubricates the engine internally, so you don't have to mix the gas/oil. But this means you will have to do periodic oil changes on the engine just like you do with a car. 4-Strokes are typically heavier than the same HP 2-stroke, but they produce less emissions, and are typically the quietest running engines overall.
There's tons more info, but thats some basics for you.
