  #1
Old August 17th, 2009, 04:39 PM
kirbster kirbster is offline
Unhappy Yamaha 200 Stuck throttles/ control box
I have a 1991 Proline with 200 hp V6 outboard w/ 9.9 yamaha 4 stroke kicker. Everything worked fine when I put the boat away in February. Last month, cleaned everything up and got her cranked, no problem. Put in the water and couldn't get the main throttle to advance beyond halfway all day. We were limited to about 10 mph, but made it work. Started up the kicker, but could not get it into gear. I took the cover off the control box and found the "black retangle shaped" piece that moves up and down to translate the throttle movement to the cable, to be stuck in the down position on the kicker motor. I'm pretty handy, but haven't done a lot of boat repair. Any help would be greatly appreciated. My wife says we can't afford any boat repairs right now......:
  #2
Old August 17th, 2009, 05:47 PM
robert graham robert graham is offline
Smile Re: Yamaha 200 Stuck throttles/ control box
probably salt, sand, dirt, corrosion. maybe some penetrating oil overnight, wash it out with fresh water, get it freed up. at the end of the season not a bad idea to spray the entire motor inside and out with WD-40. if your cables are frozen up, may have to replace them. I run just in fresh water so don't have the issues that the salt water motors have. Good Luck!
  #3
Old August 19th, 2009, 03:22 AM
Default Re: Yamaha 200 Stuck throttles/ control box
I sprayed control box with liquid wrench /WD40 with no help. Didn't seem that dirty or crusty in there. I loosened entire control box to view cables. All looks normal. I unhooked the stuck cable to the kicker motor and the motor valves moved fine. I still could not budge the cable. With the kicker cable still disconnected, I tried to advance the 200hp throttle and still only got about halfway with it. It just seems very strange that both throttle cables would fail/jam at the same time. It would seem logical that something might be wrong with the control box, but it looks normal. Are there any electrical solenoids or safety switches that might cause a problem?? Does there need to be electrical power on when I'm trying to move the throttles? I don't recall having to have it on in the past. Thanks again.
  #4
Old August 22nd, 2009, 02:25 AM
Still need help......anyone??? Bueller??
thx
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
HELP! Trying to take apart speed/tilt control arm box, now Stuck! simon_canada Johnson & Evinrude Outboards 13 June 12th, 2009 12:03 AM
Control box screws stuck eli_lilly Johnson & Evinrude Outboards 11 February 11th, 2009 11:49 PM
Throttle Control stuck nychris17 Boat Topics and Questions (not engine topics) 2 July 6th, 2003 10:43 AM
Control Shifter Stuck seabass Boat Topics and Questions (not engine topics) 2 August 8th, 2002 08:19 PM
Control Shifter Stuck seabass Non-Repair Outboard Discussions 4 August 8th, 2002 04:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
