Hi I am new to this site. I have a Polar Kraft semi V 17 1/2 foot aluminum boat with a 40/28 Yamaha Jet Drive 2 stroke outboard. I am considering cutting and Tig welding in a tunnel at the rear of the boat to allow me to raise up my jet to run in shallower water. The tunnel would be just the last 2 to 3 feet of the boat just wide enough for the jet foot to pivit against.
Has anyone installed a tunnel on their aluminum Jon boat? If you have I would love to see some pictures of your tunnel projects.
You gotta be good with metal fabbing and the tig to consider that.
Then theres the design, I'd have a good look at a few tunnel hulls.
I can imagine the tunnel being angled too sharp and drawing vacuum as the flow seperates.
The start of the tunnel is probably critical.
Too long and it draws air from under the hull.
Well I am good at Tig welding aluminum. I have a Lincoln 300 stick/Tig welder. I am just wondering if it would make enough of a difference to go through all of the work involved in installing a tunnel.
I am planning on welding up some float pods to install on the transom.
Google Woolridge Boats. They have been useing a tunnel on there squirt boats for years! Run a few ' shallower that way. Say 8" or so running rivers at 30-40+ mph
Google Woolridge Boats. They have been using a tunnel on their squirt boats for years! Run a few ' shallower that way. Say 8" or so running rivers at 30-40+ mph
I did check out their web site thanks. I know of a company near me in PA that makes some nice tunnel hull boats for jet drives http://www.snyderboats.com/faq.htm I would love to have one however they are pretty expensive. That is why I am thinking of trying to modify what I currently have. I think my boat may run 30 mph at top speed however I don't have a Speedo so I am not sure.
Snyder Boats also has some good information on maintaining your outboard jet pump in there resources section of there web site.
Jet tunnels are tricky, so look at what works and why. You'll get a few inches of improvement with a good design, a poor design will just give you headaches.
Here is another boat builder with some info on tunnel jet hulls if anyone is interested. http://www.rockproofboats.com/tunnel_hull.htm
Usually the manufacturer of the jet pump in question has a specification for mounting the jet, including the intake.
I suspect the tunnel hulls you see aren't just the same type of jet with a different hull, but a very different jet made for a tunnel hull.
That's not to say don't do it, but you should be prepared for the boat to not work right afterward, or not give any improved behavior over the old hull.
Erik
__________________
Sea Ray SRV-210 - Winter refit
75-85 foot displacement hull trawler - gleam in my eye
Erik
All the jets I have seen in my area are the same units made by Outboard Jets out of California http://www.outboardjets.com/index.php they are installed on regular outboard motors. I will check with Outboard Jets to see what they recommend.
