Need help getting a part
wolfcreek
I have a 1988 4HP Mercury model MH which I need a fule pump kit for it. The fuel pump is built into the side of the carb so I don't know if I need to get a whole carb kit or not. The problem I am running into is my local dealer says he needs the serial number to make sure he gets the right kit. I provided him my serial number A832XXX and he informed me that none of the 4hp motors had serial numbers starting with "A". Looking on line I find almost all the 4hp mercury's made in the US started with "A". Is there anyone here that could provide the part number so I can direct my local dealer to what I need OR contact me if you can supply the part and ship to Ontario Canada? Thanks.
green4themoney
Re: Need help getting a part
hey man, its not in a kit but it will due... im in ontario canada myself, i ordered from these guys and they are good with the products and shipping
http://www.crowleymarine.com/mercury_parts/340/60.cfm
just pick out the parts that you need from your pump, you can take the numbers down and go to your marine dealer or just order them online... cheers
all the parts are still readily available
