  #1
Old September 8th, 2003, 08:17 PM
chilifriedpork chilifriedpork is offline
Default Porpoising 12ft aluminum?
I know my hull isn't designed to go that fast, and that's why it porpoises. At least with only one person and little weight in the front it does.How can I fix this.I'm debating between hydrofoil and smart tabs.I don't want to scrub any top end speed, and dont fancy breaking/drilling through my cavitation plate.Any thoughts?
  #2
Old September 8th, 2003, 10:15 PM
roscoe's Avatar
roscoe roscoe is offline
Default Re: Porpoising 12ft aluminum?
Can you adjust the motor trim angle downward, closer to the boat?If not, you might want to cut a wooden wedge, and place it between your motor and the transom. A piece of wood is cheap and may give you the results you want.
  #3
Old September 9th, 2003, 04:56 AM
catfish1 catfish1 is offline
if you dont want to scrub any speed off, you may want to look at the smart tabs. do a search for smart tabs.how fast are you going now?
  #4
Old September 9th, 2003, 06:20 AM
Jdeagro's Avatar
Jdeagro Jdeagro is offline
What is your motor HP? Trimming the motor all the way down may reduce the porpoising but will also reduce the speed. Smart Tabs will give you better performance on the low end and top end, plus get rid of the porpoising.
__________________
Get SX Smart Tabs cosmetic blems for an extra $20 off (only $99.95) exclusively at iboats.com
link: http://www.iboats.com/Nauticus_SX_Sm...2485--dz.54646
  #5
Old September 9th, 2003, 04:25 PM
Well, it's a '75 15hp. More like a 13hp.rated at prop.Because of the smaller displacement, it doesn't perform as well with weight in it, than say a 20 hp.(bigger disp.)I don't know the exact speed, but it's too fast to control when it porpoises. Plus, the main problem being, I am afraid when porpoising the air will get packed under the boat and flip her over, kinda like a sail!I know about smart tabs. I think they run about 130$CAN. Perhaps it's worth a shot.My boat's only 4 feet wide, so I kinda want to upgrade to a wider 12 footer, possibly with a V shaped hull(near the stern)I'll see what happens...Anyone had experience with smart tabs on a cartop?
  #6
Old September 9th, 2003, 06:35 PM
MurdockJr MurdockJr is offline
Sounds like too much power and weight for that boat.
  #7
Old September 9th, 2003, 09:52 PM
I could'a told ya that!
  #8
Old September 10th, 2003, 06:23 AM
Jdeagro's Avatar
Use the ST780-20 Smart Tabs, and the ride, handling, and planing problems will go away. The boat will become ver stable.
__________________
  #9
Old September 11th, 2003, 01:08 PM
mbrueck mbrueck is offline
Make a tiller extender out of PVC and sit on the middle seat when you're by yourself.
  #10
Old September 12th, 2003, 07:27 PM
rodbolt rodbolt is offline
hello I have the same problem with my voyager 14 6ft beam jon boat with a 35 rude and stainless 13 pitch prop. I found the only way to cut the porposing was to raise the motor on the transom and add weight to the bow. the other lesson I learned is 90 degree turns in the ditch ( about 10 ft wide) are impossible but long walks out of the marsh grass are good luck and have fun
  #11
Old September 13th, 2003, 10:18 AM
I have a tiller handle made, but am a little leary the strength of the plastic twist grip piece. Plus, there is some free play in the twist throttle piece, and with that much leverage/extension there would be too much free play for my liking. Then, in tight turns, you have to swing that pvc pipe way out to one side in order to get a sharp turn. I'll think about it.-230$ (Can.)for trim tabs? I guess it's worth it.Thanks all for your suggestions!
  #12
Old September 17th, 2003, 07:15 AM
Jdeagro's Avatar
Cartoper;$230.00 even in Canada sounds a bit high. The size you need is $99.00 in the USA from most major retailers. It is an easy Do it yourself install so that would also save money. Who are you going to buy them from? maybe i can help find aetailer for you. the cost should be well below $200.00 for the ST780-20
__________________
  #13
Old September 17th, 2003, 10:44 PM
Boatist's Avatar
Boatist Boatist is offline
I had the same problem with my 1967 14 foot 67 inch wide boat with a 1975 15 HP Johnson.It was fine with some one in the front seat or middle seat but when alone the front was too light and out of control. Moving the gas tank and my tackle box up front helped.I made a big improvement for about $5. What I did was to just make my own trim tab out of a 1 inch square aluminum tube. I formed the tube a little so not quite square and to give it a little more down angle. I did not want to drill any holes in the boat so I glued it on with Silcone seal. I worried for weeks it would come off while running hard but it is still on there today. I used two 1 inch square aluminum tubes 1/16 inch thick from the chines to about 6 inches form the motor. In later years I filled each with closed cell fome so it would flote if it ever came off.With a buddy in the boat with me I could not tell the difference but when alone made a big difference. The bow while still light would no longer come way up and scare me. I do not know if the top speed is slower or not but can tell you for me I got to my fishing hole a lot faster. Before I was staying just up on plane and still kind of out of control. With the change I could go way over planeing speed and on nice day run full throttle.To give it a try and to make it eaiser to adjust your angle just get some 1 or 1 1/2 inch aluminum angle 1/16 inch thick. Only reason I used the square tube was so I could fill it with flotation and I though less likely to cut fishing line.
__________________
Have some fun and enjoy the Great Outdoors.
Love to fish out of Bodega Bay, California.
  #14
Old September 18th, 2003, 01:39 PM
envy83 envy83 is offline
Throw a sandbag in the front seat. 50 lbs will cost you maybe a mile an hour, and you'll get it back with the smoother ride. cost'-$3.00 CA tops.
  #15
Old September 18th, 2003, 04:53 PM
perchjerker perchjerker is offline
My brother had a 13 ft raycraft with a 70 hp johnson. It porpoised at slow speeds and he had to drive it wide open to stop the porpoising. Too large of a motor on too short of a boat I guess.Also had a friend who had a 9 ft. fiberglass hydroplane with a 40 horse chrysler, porpoised real bad unless you put some weight in the front. Was water skeeing behind it and was on a slalom, it kept slowing down and my ski was sinking, I kept motioning for him to speed up and he said this #@$%ch is sinking. He couldnt slow down or it wouldn't make it to the boat ramp. I had to pull myself in with the ski rope and sit on the front of the boat to keep it planed. Got to the ramp and sunk it on the trailer. It had been patched and the patch peeled off.
  #16
Old September 19th, 2003, 06:14 AM
Jdeagro's Avatar
Guys;You all are on track the problem with stern drive and stern mounted engines is balance. Get the boat in balance and most of the handling problems will go away. Unfortunately what balances the boat today may not work tomorrow when you bring your 100 lb dog. That is why fixed devices are a cumbersome answer. You will always need to make some adjustment or put up with a handling problem.The common attitude is that as long as the boat can get on plane it does not need trim tabs. That is a very narrow look at the benefits of trim tabs. Put enough HP on the but of an elephant and it will plane, but that does not mean it is going to handle very well. Permanently fixed planing devises(sand bags, metal strips and the transome, hydrofoils) will all provide some level of correction for a specific characteristic at a specific speed or under specific conditions, but they can degrade the performance under other situations. Since we operate boats in ever changing conditions (speed , weight, water currents, etc.) the control device should also be variable. This opens the window of effective use dramatically. That is why all airplanes have flaps and trim tabs. These variable surfaces changes the hull design to compensate for all of the changing conditions, as the plane moves through the air (which is a liquid too). Size of the airplane or boat makes little or no difference.
__________________
  #17
Old September 19th, 2003, 11:23 AM
I agree Nautijohn, I think it comes down to what you want to spend, and what your looking to get. A $3 sandbag will stop the porposing (kind of) but it adds weight and its a static fix, a $50 hydroplane cuts the weight but it's still static, and a $150 set of tabs will smooth it out in most situations because its active. Take your pick, find the $$ amount that best describes how bad you want it fixed.
  #18
Old September 19th, 2003, 01:41 PM
Jdeagro's Avatar
Envy83,Smart Tabs list prices range from 99.00 to 149.00 to 199.00. For this appication they would be 99.00 at most retail outlets. One last note adding weight to the boat or making it run bow down will increase fuel consumption, and it isn't free. Although the enginenis small and does not use too much to begin with, every time it is used it will cost more.
__________________
  #19
Old September 19th, 2003, 02:10 PM
cobra 3.0 cobra 3.0 is offline
Just install a Stingray hydrofoil on the foot of the motor for about $35.00. Your boat will handle like a dream! I had an 18 hp Mercury on a 13 1/2' princecraft cartopper with similar problems. The hydrodoil eliminated the problem and made the boat extremely stable...especially in turns.
  #20
Old September 19th, 2003, 05:03 PM
On a 16ft inflatible we have, a stingray hyrofoil has been added, and yes it does help keep the bow down etc.I would rather use the tabs though, seems a little better in the long run.Thanks for all the imput, now, time to make the decision...ps. I don't think my transom can handle any more pressure that a hydrofoil would apply! LOL
  #21
Old September 19th, 2003, 08:10 PM
Skinsk Skinsk is offline
buy or make yourself a 6-8ft fuel line, and your fuel tank up front..
  #22
Old September 21st, 2003, 07:52 PM
Lark40 Lark40 is offline
A boat as light as yours is going to porpoise when speeding. That's a fact of life.Lots of good ideas above, but I doubt you're ever going to fully solve the problem.
  #23
Old September 21st, 2003, 08:20 PM
BR549 BR549 is offline
On my old flatbottom I put an 5 gallon container of water ( one of those plastic gas containers you can get for 10 dollars)in the front of the boat. You can add or remove water to get the right balance - worked great for me at a minimal cost.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Motor for 12ft aluminum fishcracker Boat Topics and Questions (not engine topics) 19 May 31st, 2006 09:42 PM
Porpoising aluminum boat. Bwalker Non-Repair Outboard Discussions 3 October 7th, 2005 04:32 AM
12ft glass boat value mattoc Boat Topics and Questions (not engine topics) 3 April 12th, 2004 05:49 PM
12ft aluminum applebee rowboat how much worth? kdmiller8251 Boat Topics and Questions (not engine topics) 4 February 27th, 2004 12:45 PM
Shining up a 12ft aluminum cartop chilifriedpork Boat Topics and Questions (not engine topics) 0 June 19th, 2003 06:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
