Re: Seal Concrete Pond
Well, you have to drain it either way so a liner is still an option.
BTW- since it is a fish pond, you'll probably want a non-toxic solution to the problem. Beware, many epoxy formulations may be toxic to fish even when cured.
First time I ran across this, it was for a concrete bird bath. There are some products out there for that purpose but they might be cost prohibitive for a large pond.
One thought I had was the products they make for sealing basement walls. Drylok is one product I believe and is available at any home improvement store. You'd have to check the label to see if it is non-toxic when cured.
