Re: Changing Impeller on a Mariner
The shift shaft goes all the way thru to the top of the powerhead.
There's a clip that holds the shaft in place to the shift linkage. Pull the clip upwards to unlock it, then pull straight to the outside to release.
You'll also have to undo the reverse latch actuator in order to pull the shaft down. It's the piece you see in the 2nd picture, the one that pushes on the reverse lockout latch when the shift shaft moves up and down. Be sure to mark or otherwise note its position for reinstallation.
One caveat on this lower unit, the shift shaft screws into its actuator inside the gearcase. Do Not spin the shift shaft around once the lower unit is pulled. This changes the shifting adjustment and you will Sorely Regret having done so! You don't wanna know how I know this, either!!!
HTH & G'luck...........ed
