Hi all,
This is for 2001 135 optimax with Type II PTT. Unable to find answer in search. I replaced the electric motor on my PTT (leaking water around wires and finally gave out). The hydraulics had no indication of ever leaking. Have the whole assembly removed from the motor. I filled the resevoir as per seloc shop manual and extended trim and tilt. Shop manual says to cycle the system a few times to purge air while chceking fluid level when fully extended each time. The bypass valve is closed and the fill cap is closed(other than when checking fluid when tilted full out). The problem is when I try to cycle the system the tilt ram will retract but the trim rams fail to retract. The motor will run but the trim rams will not retract.
Any help would be appreciated.
Thanks
Sketter
Thanks
Sketter
