Re: fuel gauge problem on 2001 yamaha 150
Call Bayliner customer service with your hull info regarding the capacity of the tank. As far as the actual fuel gauge, I would start with the in tank sending unit. If your tank has a bad ground it will cause the sending unit to burn out, I just replaced 2 until i found the culprit. Are you running a Yamaha multi gauge or analog? the 150 should burn about 8-12 gph at 4000 rpm cruise, that all depends on the load, i.e. what type of hull you have, seas, weight ect. I have bypassed the Yamaha digital gauge and opted for analog gauges due to ease of reading I mean how much is 2 lit bars really?
__________________
Happiness is like peeing in your pants, everyone can see it's effect but only you can feel it's warmth
25' Aerotek 250 Yamaha OX66
21' W/A 200 Yamaha 200 TXRR
