I took a bolt I removed to a local fastener place and they said they thought it was aluminum. I don't know how to tell. It is not magnetic but ss bolts aren't really either. Any ideas? How are your rails attached?
Keith
mine are bolts, i would assume ss... i didnt think aluminum would be that common... cant be very strong...
My question would be why are you so concerned over what it came with it originally? ss would out perform al any day in terms of shear strength.
Keith I have a better question . Why are you replcing them ? I just bagged and tagged mine so I can put them back in when I get to that point . Try Fastenal or Grainger . I ended up getting Rivets at Grainger as I only had to order 250 of them insted of the 500 from Fastenal.
Rick
One reason that I was going to go back with the aluminum (if that is what it is) is to avoid electrolysis issues. I will have this boat in the bay part of the time. I do realize that it is going to be difficult to get much salt water inside the rub rail for that to be an issue but I am a big fan of over-engineering.
Keith
Yeah, I know. It just concerned me that if that is what was on the boat originally, then I should probably go back with that. I will hit another fastener shop today and see if they can tell me if it is aluminim or ss.
Keith
Easy ways to tell:
compare weight to a steel bolt the same size and length. A SS bolt will weight about the same, and Al one will be 1/3 of the weight.
Hit one of your old ones with a grinder. SS will throw off red sparks, Al - no spark at all.
I very highly doubt those bolts are aluminum though, with over a decade in the steel fab industry, specializing in SS and Al work, along with a couple of years working as a warehouseman for a major bolt supplier/manufacturer, I never once heard of an Al bolt. It would be way too soft and prone to thread stripping it wouldn't be funny.
Well, I'll be darned, look at this:
http://www.racebolts.com/index.php?main_page=index&cPath=675
Pricey buggers though. almost $2 each for what would be a 5/16" x 1" flathead machine screw...
Cool, they have Titanium bolts too. Almost $6 each for the same size listed above...
I never once heard of an Al[uminum] bolt.
