Evinrude Boater
- Jul 6, 2004
- 1,148
I have a stray black wire from the ignition amplifier. The wiring diagram shows it going to the distributor through a grounded bolt. Looking at the bottom of the distributor there's one machine screw sticking out far enough to attach the wire and I found a small nut in the bilge. Is this where the black ground wire is supposed to be attached?
