  #1
Old August 15th, 2009, 08:25 PM
Rodlite85 Rodlite85 is offline
Default 1978 115 evinrude comp. loss
I have a 1978 115 motor. Checked compression before i bought it back in the fall. All cylinders were 110-115. I've ran it several times this year with no troubles or problems. Time before last that i took it out, I lost fire on one cylinder. I replaced coil, then found that it was the power pack had one channel not firing in it. Replaced that. Took the boat out this last time and it ran rough for a moment, then cleared out and ran fine for about 30 mins. It seemed to only be runnin on 2 or 3 cylinders after that. I got it home, ran a compression test, and both bottom cylinders have no compression. Reed plate looks fine, Cylinders dont seem to have any scarring. Also, starter doesn't turn motor over as fast the past few times i've had it out. Any help?
  #2
Old August 16th, 2009, 09:51 AM
115johnson78 115johnson78 is offline
Default Re: 1978 115 evinrude comp. loss
How much compression on the cyl.? If just a few psi lower the try to decarbon it. If it is down around 40-70 psi then pull the heads and have a look. As for the starter check all of your conectiions.
  #3
Old August 17th, 2009, 10:49 PM
I have since then removed the exhuast plate and heads. Pistons are trashed. Thanks for the help though
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
62' evinrude comp. question zgbgwfs Johnson & Evinrude Outboards 6 May 9th, 2009 06:52 PM
85 40hp Evinrude low comp on top cyl Mr. Catfish Johnson & Evinrude Outboards 2 March 31st, 2009 10:34 PM
Loss Of Power - 1978 140 hp Johnson AguaSki Johnson & Evinrude Outboards 9 October 5th, 2008 06:23 PM
evinrude 75 hp middle cyl. comp. low mcguyvermike Johnson & Evinrude Outboards 6 December 16th, 2006 05:13 AM
1977 evinrude 140hp no comp 1 cylinder feral Johnson & Evinrude Outboards 7 March 20th, 2005 01:41 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
