  #1
Old August 15th, 2009, 08:15 PM
paulNM paulNM is offline
Default 90 hp Mercury Motor Heat Sensor
I have a 90 HP Mercury Motor - I have replaced the impeller. Overheat alarm comes on continuously even without motor started. I have run the motor at idle - engine block and heads are not hot, but alarm continues. I am assuming the sensor or wiring is the cause??? Any comment or help would be appreciated.
  #2
Old August 15th, 2009, 08:38 PM
Silvertip Silvertip is offline
Default Re: 90 hp Mercury Motor Heat Sensor
Disconnect the sensor. If the alarm quits, the sensor is the issue. If not, the module is probably toast or the tan wire from the sensor is shorted to ground (that's what the sensor does).
  #3
Old August 16th, 2009, 10:58 AM
pattymilink pattymilink is offline
Where is the heat sensor located on the engine block to disconnect it?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Heat sensor OBJ Mercury & Mariner Outboards 0 July 7th, 2006 11:45 PM
dt85 heat sensor river37091 Yamaha & Suzuki Outboards 8 July 14th, 2005 01:01 AM
test heat sensor olgeezer Johnson & Evinrude Outboards 3 February 25th, 2004 11:09 AM
High heat/ Low oil sensor Fontaine Mercury & Mariner Outboards 0 June 15th, 2003 07:14 AM
over heat sensor? ozarkjeep Force & Chrysler Outboards 2 June 17th, 2001 05:01 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
